OleJ Posted January 29, 2023 Posted January 29, 2023 Hei, en god dag til dere. Har en Kuga 2014 modell. Diesel automat. To ganger har bilen fått opp en "haug" med feilkoder, gir melding(er) om at ting ikke funker og motoren stopper. Tror ikke jeg har feilkoder ved akkurat de stoppene, men har to bulker med feil som jeg har fått kopiert ut. Stoppet den 10/1 var en uke på et verksted før de transporterte den til merkeverksted hvor den har vært siden. De feilsøker visst fortsatt. (Ringte etter 5 dager for å høre om de fortsatt skulle feilsøke da "kronasjen" kunne øke kraftig.) Legger ved de to feil filene jeg har. Mvh Ole Johnny Mener denne datert 22/1-22 ******************************************* Car Scanner ELM OBD2 DTC report Selected brand: Ford VIN: WF0AXXWPMAEU79470 ============1============== U0104(00) Raw code: C10400 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear OBDII: Data bus, cruise control module - no communication ============2============== P188C(00) Raw code: 188C00 ECU: Engine control unit[Archive (inactive)] Status: Test failed since last DTC clear OBDII: ALL WHEEL DRIVE RELAY MODULE COMMUNICATION CIRCUIT ============3============== P068A(00) Raw code: 068A00 ECU: Engine control unit[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Engine control (EC) relay - shut-off early ============4============== P1139(01) Raw code: 113901 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Water In Fuel Indicator Circuit Malfunction Ford: Water In Fuel Indicator Circuit Malfunction ============5============== P1140(00) Raw code: 114000 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Water In Fuel Condition Ford: Water In Fuel Condition ============6============== P003A(91) Raw code: 003A91 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Turbocharger (TC)/supercharger (SC) boost pressure control A - learning limit exceeded ============7============== P003A(85) Raw code: 003A85 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Turbocharger (TC)/supercharger (SC) boost pressure control A - learning limit exceeded ============8============== U2101(00) Raw code: E10100 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: CAN data bus - ECM incorrectly programmed ============9============== P0094(00) Raw code: 009400 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Fuel system leak - small leak detected ============10============== P0093(00) Raw code: 009300 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Fuel system leak - large leak detected ============11============== P169F(00) Raw code: 169F00 ECU: Engine control unit Status: Test not completed during this operation cycle ============12============== P1531(96) Raw code: 153196 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Invalid Test - Accelerator Pedal Movement Ford: Invalid Test - Accelerator Pedal Movement ============13============== P0219(00) Raw code: 021900 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Engine over speed condition Ford: Engine Overspeed Condition ============14============== P0266(92) Raw code: 026692 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Cylinder 2 - contribution/balance fault Ford: Cylinder #2 Balance Fault ============15============== P0272(92) Raw code: 027292 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Cylinder 4 - contribution/balance fault Ford: Cylinder #4 Balance Fault ============16============== P0269(92) Raw code: 026992 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Cylinder 3 - contribution/balance fault Ford: Cylinder #3 Balance Fault ============17============== P0263(92) Raw code: 026392 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Cylinder 1 - contribution/balance fault Ford: Cylinder #1 Balance Fault ============18============== P1774(02) Raw code: 177402 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle ============19============== P1643(64) Raw code: 164364 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Fuel Pump Monitor Circuit Low Input Ford: Fuel Pump Monitor Circuit Low Input ============20============== P1774(64) Raw code: 177464 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle ============21============== U0404(64) Raw code: C40464 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Invalid data received - gear shift module ============22============== P061C(64) Raw code: 061C64 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Engine control module (ECM), engine rpm - performance problem ============23============== P1304(00) Raw code: 130400 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: EGR Calibration High Ford: EGR Calibration High ============24============== P1304(91) Raw code: 130491 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: EGR Calibration High Ford: EGR Calibration High ============25============== P1304(85) Raw code: 130485 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: EGR Calibration High Ford: EGR Calibration High ============26============== P1936(31) Raw code: 193631 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle ============27============== P164D(00) Raw code: 164D00 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle Ford: ALL WHEEL DRIVE ID BLOCK CORRUPTED, NOT PROGRAMMED ============28============== U0418(00) Raw code: C41800 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Invalid data received - brake system control module ============29============== U0426(00) Raw code: C42600 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Invalid data received - immobilizer control module ============30============== P188C(00) Raw code: 188C00 ECU: Engine control unit[Archive (inactive)] Status: Test failed since last DTC clear OBDII: ALL WHEEL DRIVE RELAY MODULE COMMUNICATION CIRCUIT ============31============== U0104(00) Raw code: C10400 ECU: Engine control unit[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear OBDII: Data bus, cruise control module - no communication ============32============== P068A(00) Raw code: 068A00 ECU: Engine control unit[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Engine control (EC) relay - shut-off early ============33============== U0126(00) Raw code: C12600 ECU: ABS/ESP[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Data bus, steering position sensor control module - no communication ============34============== U0401(00) Raw code: C40100 ECU: ABS/ESP[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Invalid data received - engine control module (ECM) ============35============== U0104(00) Raw code: C10400 ECU: ABS/ESP[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Data bus, cruise control module - no communication ============36============== U3003(16) Raw code: F00316 ECU: ABS/ESP[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle OBDII: Battery voltage ============37============== U0437(68) Raw code: C43768 ECU: ABS/ESP[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Invalid data received from differential control module, rear ============38============== U0257(00) Raw code: C25700 ECU: APIM Status: Test failed, Test failed (current drive cycle), Confirmed OBDII: Lost communication with front controls/display interface module ============39============== U3003(16) Raw code: F00316 ECU: APIM[Archive (inactive)] Status: Confirmed OBDII: Battery voltage ============40============== B1D38(16) Raw code: 9D3816 ECU: BCM[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear ============41============== B1D38(19) Raw code: 9D3819 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear ============42============== B1088(86) Raw code: 908886 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear ============43============== U3003(16) Raw code: F00316 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Battery voltage ============44============== U3008(13) Raw code: F00813 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Control module - earth connection A ============45============== B12BD(83) Raw code: 92BD83 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear ============46============== U0264(87) Raw code: C26487 ECU: BCM Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear OBDII: Lost communication with camera module ============47============== B1390(87) Raw code: 939087 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear Ford: Oil Temperature Sensor Circuit Short To Ground ============48============== B1287(15) Raw code: 928715 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear Ford: Servo Motor Potentiometer Airintake Left Circuit Short To Ground ============49============== B1D13(11) Raw code: 9D1311 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear ============50============== B109B(15) Raw code: 909B15 ECU: BCM Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear ============51============== B1133(11) Raw code: 913311 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear, Test not completed during this operation cycle ============52============== U0104(00) Raw code: C10400 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Data bus, cruise control module - no communication ============53============== U0405(81) Raw code: C40581 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Invalid data received - cruise control module ============54============== U2001(87) Raw code: E00187 ECU: BCM[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Audio Tape Deck Unit is Not Responding Ford: Audio Tape Deck Unit is Not Responding ============55============== B1A57(87) Raw code: 9A5787 ECU: HCM[Archive (inactive)] Status: Test failed since last DTC clear, Test not completed during this operation cycle ============56============== B1A58(87) Raw code: 9A5887 ECU: HCM[Archive (inactive)] Status: Test failed since last DTC clear, Test not completed during this operation cycle ============57============== B1A59(11) Raw code: 9A5911 ECU: HCM[Archive (inactive)] Status: Test failed since last DTC clear, Test not completed during this operation cycle ============58============== B1C98(13) Raw code: 9C9813 ECU: HCM[Archive (inactive)] Status: Test failed since last DTC clear, Test not completed during this operation cycle ============59============== B1C99(13) Raw code: 9C9913 ECU: HCM[Archive (inactive)] Status: Test failed since last DTC clear ============60============== U0001(88) Raw code: C00188 ECU: HCM Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle OBDII: Controller area network (CAN) data bus, high speed bus ============61============== U3003(16) Raw code: F00316 ECU: HCM[Archive (inactive)] Status: Test failed since last DTC clear, Test not completed during this operation cycle OBDII: Battery voltage ============62============== U3003(13) Raw code: F00313 ECU: PSCM[Archive (inactive)] Status: Confirmed OBDII: Battery voltage ============63============== U0140(00) Raw code: C14000 ECU: RCM[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Data bus, body control module (BCM) - no communication ============64============== U0253(00) Raw code: C25300 ECU: RCM[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear OBDII: Lost communication with accessory protocol interface module ============65============== U2300(64) Raw code: E30064 ECU: RCM[Archive (inactive)] Status: Confirmed, Test failed since last DTC clear ============66============== U3003(16) Raw code: F00316 ECU: RCM[Archive (inactive)] Status: Test failed since last DTC clear OBDII: Battery voltage *********************** Denne fra 31/12-22 Car Scanner ELM OBD2 DTC report Selected brand: Ford VIN: WF0AXXWPMAEU79470 ============1============== P1139(01) Raw code: 113901 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Water In Fuel Indicator Circuit Malfunction Ford: Water In Fuel Indicator Circuit Malfunction ============2============== P1140(00) Raw code: 114000 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Water In Fuel Condition Ford: Water In Fuel Condition ============3============== U2101(00) Raw code: E10100 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: CAN data bus - ECM incorrectly programmed ============4============== P0094(00) Raw code: 009400 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Fuel system leak - small leak detected ============5============== P0093(00) Raw code: 009300 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Fuel system leak - large leak detected ============6============== P169F(00) Raw code: 169F00 ECU: Engine control unit Status: Test not completed during this operation cycle ============7============== P1531(96) Raw code: 153196 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Invalid Test - Accelerator Pedal Movement Ford: Invalid Test - Accelerator Pedal Movement ============8============== P0219(00) Raw code: 021900 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Engine over speed condition Ford: Engine Overspeed Condition ============9============== P0605(48) Raw code: 060548 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Engine control module (ECM) - ROM error Ford: Powertrain Control Module ROM Test Error ============10============== P1774(02) Raw code: 177402 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle ============11============== P1643(64) Raw code: 164364 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Fuel Pump Monitor Circuit Low Input Ford: Fuel Pump Monitor Circuit Low Input ============12============== P1774(64) Raw code: 177464 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle ============13============== U0404(64) Raw code: C40464 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Invalid data received - gear shift module ============14============== P061C(64) Raw code: 061C64 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Engine control module (ECM), engine rpm - performance problem ============15============== P1304(00) Raw code: 130400 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: EGR Calibration High Ford: EGR Calibration High ============16============== P1304(91) Raw code: 130491 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: EGR Calibration High Ford: EGR Calibration High ============17============== P1304(85) Raw code: 130485 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: EGR Calibration High Ford: EGR Calibration High ============18============== P2002(00) Raw code: 200200 ECU: Engine control unit Status: Test not completed during this operation cycle OBDII: Particulate trap, bank 1 - efficiency below threshold ============19============== P1936(31) Raw code: 193631 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle ============20============== P164D(00) Raw code: 164D00 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle Ford: ALL WHEEL DRIVE ID BLOCK CORRUPTED, NOT PROGRAMMED ============21============== U0418(00) Raw code: C41800 ECU: Engine control unit Status: Test failed, Test failed (current drive cycle), Test not completed during this operation cycle OBDII: Invalid data received - brake system control module ============22============== U0426(00) Raw code: C42600 ECU: Engine control unit Status: Test not completed since last DTC clear, Test not completed during this operation cycle OBDII: Invalid data received - immobilizer control module ***************************
grcossie Posted January 29, 2023 Posted January 29, 2023 Hei, her høres det ut som det kan være noe på ledningsnett. Starter bilen igjen med en gang ? Her kan det være forsikringa kan dekke noe
OleJ Posted January 29, 2023 Author Posted January 29, 2023 Hei grcossie, tusen takk for svar. Det var litt variabelt. Men ja, etter en liten stund hvor jeg måtte ta av/på tenningen så startet den, men tålte ikke å tas i gir og bittelitt gasspådrag, da var det stopp. (🥴 håper den gjør det jeg og) Mvh Ole Johnny
Sierrakaren Posted January 29, 2023 Posted January 29, 2023 Orginalt batteri? Batteri som har dårlig celle kan få bilen til og slå ut mangen feilkoder. Men ja kabelbrudd eller dårlig jording er også ein mulighet Nåverende biler: 91 Ford Sierra stv doch 90 Ford Sierra Cosworth 4x4 09 Ford mondeo duratec
siggen Posted March 13, 2024 Posted March 13, 2024 Hei. Hva ble løsningen på denne? Har en med akkurat samme feil. Ved feilsøking så er feilen selvsagt ikke der😅
