skivebremser bak??
Guest konrad
noen som har bytta til skivebremser bak på en escort rst???
veldig mye jobb??
Ikkeno problem det..
What you need:
2wd Sierra/Granada rear calipers, 4-stud discs  and pads. Caliper mounting brackets (to match the chosen disc size) and fitting bolts. Mk5/6 RS2000 handbrake cable. Longer flexible brake hoses.
2wd Cosworth rear calipers and discs are pressed into service on the rear. All Sierra/Granada rear calipers are actually the same, the only variations being 4x4 Cosworth Sapphire/Escort Cosworth/late Scorpio which used vented discs - the vented disc setup can also be used, but are much harder to come by and consequently much more expensive - in reality on a car of this weight, they really aren't necessary.
http://users.turbosport.co.uk/cossieclint/.../s1rearconv.htm
Guest konrad
takk takk..
men engelsken er det værre med...
