Toresin Posted July 8, 2015 Posted July 8, 2015 Heisann, hvordan finner jeg ut om denne er levert med fjernkontroll. Kjøpte bilen fra dødsbo og det ble funnet bare en nøkkel Spurte på den lokale ford pusher,men di sa bare,,, kanskje,,muligens,osv,osv
Toresin Posted August 1, 2015 Author Posted August 1, 2015 For noe dritt,ikke en av låsene virker ordentlig.samtlige veies rundt sammen med nøkkelen.Og hva er dette med å vri to ganger for å låse opp bakdøreneEr dette mulig får vekk
Mondeo Power Posted August 1, 2015 Posted August 1, 2015 Den er levert med fjernkontroll. Hadde du hatt den kunne du programert så alle dørene ble låst opp ved et trykk.
Toresin Posted August 1, 2015 Author Posted August 1, 2015 Takker, må jeg kjøpe ny fjernkontroll fra ford,eller kan jeg Ebay
Mondeo Power Posted August 1, 2015 Posted August 1, 2015 Går fint på ebay. Bare ikke de billigste for de er uten innmat.
Stian MH Posted August 12, 2015 Posted August 12, 2015 Dette skal funke fint 1. Close all the doors.2. Turn Ignition key from position 0 to II eight times within 10 seconds.3. Make sure the vehicle locks and unlocks the doors.4. Press the remote transmitter button within 20 seconds., and make sure the vehicle locks and unlocks all the doors.5. Up to 20 seconds is allowed to programme the next remote transmitter.6. To programme additional remote transmitters, repeat steps 4 and 5.7. Turn the ignition key to position 0 to exit the programming mode.Note : Maximum 4 remote transmitters may be programmed.Note : . Ensure the vehicle battery is fully charged and the anti-theft alarm system is not armed or triggered.Note : If programming ends with no new remote transmitters, the originals are retained.Note : The anti-theft alarm and double locking module will exit programming mode automatically if four new remote transmitters have been programmed or if no new remote transmitter has been programmed within the 20 second programming mode.Kan kjøpe denne f.eks: http://www.aliexpress.com/item/FREE-SHIPPING-3-BUTTON-Top-Quality-433MHZ-REMOTE-ENTRY-KEY-FOB-FOR-FORD-MONDEO-FIESTA-FOCUS/32234786022.html [] 07 Audi A6 Allroad 2.7 TDi Q, kvartsgrå. [] 15 Ford Fiesta 1.0 Ecooboost titanium, candy blue [x]10 VW Golf 1.6 TDi shark blue "sommerblå"[x]11 Ford Focus 1.6TDCi Titanium, Candy Red[x]01 Ford Mondeo 2.0L GHIA, pepper red
roy@pumpa.no Posted January 13, 2016 Posted January 13, 2016 -Og der bestilte jeg en også gitt.Kjapt gjort.Kan være greit å slippe selve fjernkontrollen.
