cosworth parts
RSCLASSICS
cosworth breaking 2wd and 4x4 parts
OSWORTH PARTS UPDATED
WILL POST INTERNATIONALLY AND TAKE PAYPAL !!!!!!!!!!!
PARTS ALWAYS CHANGING
STOCK ALWAYS CHANGING AND CURRENTLY BREAKING ONE 2WD AND ONE 4X4 COSWORTH
BLING AND SHINNY BITS (JUST ASK MORE IN STOCK)
BLACK ALLOY CAMBELT COVER £65
SLAM PANEL BLANKS £12.50
STAINLESS HEAT SHIELD £117.50 SOLD!!!!!!
FUSE BOX COVER £20
OIL SCREW CAP £20
AMAL VALVE COVER £17.50 SOLD!!!!
ACTUATOR COVER £17.50
ALLOY PAS TANK £55
AIR BOX CLIPS £12.50
WHEEL CAPS REVOLUTION £10
4X4 STEERING WHEEL £75
COLLINS BOOST GAUGE £35
GROUP A FILTER £55
stainless bottom rad pipe 2wd £20
BAILEY 2WD HEADER TANK £85
SWEDISH STYLE PLENIUM LIKE NEW COMPLETE WITH BRACKET AND THROTTLE BODY (BLUE) £400
SWEDISH PLENIUM THROTTLE CABLE BRACKET £25
STANDARD 2WD REGULATOR NEVER BEEN MESSED WITH £45 SOLD!!!!!!!!
STAINLESS CONE FILTER COVER £25
RS TURBO OIL CAP £15
ENGINE PARTS (JUST ASK MORE IN STOCK)
4X4 ENGINES FROM £2500
2WD COMPLETE ENGINE £2300
GREEN INJECTORS 803 £125 PLUS POST
YELLOW INJECTORS £45 POSTED
LIGHT BLUE INJECTORS MOTORSPORT 400 £150 POSTED
GREY INJECTORS £125
4X4 CRANK STANDARD GRIND £450 ono SOLD!!!!!
4X4 THROTTLE POSITION SENSOR PFO9 RED £75 ono
4X4 THROTTLE POSITION SENSOR PFO9 BLACK £75 ono SOLD!!!!!!!!!
4X4 SUMPS £85
2WD SUMPS £110
2WD/4X4 BOTTOM PULLEYS £75
2WD OIL PICK UP PIPE £35
4X4 OIL PICK UP PIPES
2WD CAM BELT COVER £35
HT LEADS £45 SILICON
CAM COVERS FROM £125 PLUS POST £12.50
RED SILICON BOOST HOSES £55
ORIGINAL 2WD DIPSTICK AND SHROUD £30
BOOST HOSES £55
RAD FANS £25
2WD INTERCOOLER £35
4X4 HEAT SHIELD FOR VENTED BONNETS £40
GROUP A COIL £15
boost pipe RS500 £70
RS 500 INTERCOOLER £125
motorsport ht leads £55 plus post
4x4 turbo very good £225
WATER INJECTION TANK £45
2WD AND 4X4 ABS PUMPS £45
SAMCO BOOST HOSES BLUE £55
3 bar map sensor repaired and works perfectly £45
GROUP A COIL £15 PLUS POST
ESCORT COSWORTH STANDARD MAP SENSOR £25 PLUS POST
4X4 INTERCOOLER £55 PLUS POST
4X4 MANIFOLD £100 TINY CRACK
2WD SANDWICH PLATES £25
4X4 SANDWICH PLATES £20
TRANSMISSION (JUST ASK MORE IN STOCK)
2wd gearbox complete with bell housing and fork (no mount) £550
4X4 GEARBOX £275
2WD GEAR LEVER £25
2WD FRONT HUBS £85
ABS SENSORS £20 EACH
ABS PUMPS £70
STEERING RACKS £75 2WD AND 4X4
ANTI ROLL BARS £35
2WD/4X4 FRONT CALIPERS £85
2WD/4X4 REAR CALIPERS £85
2WD AND 4X4 KONIS £175
V GOOD 2WD 7.5 INCH REAR DIFF £250
QUAIFFE DIFF 2WD £1000 ono
2WD REAR CROOVED DISCS £40 PAIR
2WD DRIILLED AND GROOVED FRONT DISCS £30 PAIR
REAR DRIVESHAFTS £85 PAIR 2WD AND 4X4
REAR BEAMS £35
REAR ARMS BARE £25 EACH
PROP SHAFTS 2WD £45
WHEELS (JUST ASK MORE IN STOCK)
ESCORT COSWORTH WHEELS AND GOODYEAR TYRES £600
5 SHARKTOOTH WHEELS AND CAPS GOOD MATCHING TYRES £400
3DR COSWORTH WHEELS X4 £175
3dr wheels available we have over 70 of them that need some re-furd £35 each
3DR WHEEL LOCKS AND KEYS £175
3DR WHEEL CAPS £25 EACH
SAPPHIRE WHEELS SET OF 4 £175 WITH TYRES
BLACK SAPPHIRE SET OF 4 £145 NO TYRES SOLD!!!!!!!!!!!!!!!
17 INCH KHANS £225
17 INCH OLD SCHOOL CHROME WHEELS £150
5 SPOKE MO COMPOMOTIVES £700 SET OF 4 WITH TYRES SOLD!!!!!
TSW 18 INCH WHEELS £350 SET OF 4 SOLD!!!!!!
BODY PANELS (JUST ASK MORE IN STOCK)
SAPPHIRE COSWORTH REAR SPLASH GUARDS £30 EACH OR £50 PAIR
sapphire grilles £45 plus post
sapphire grilles less centre £20
SAPPHIRE COSWORTH HEATED FRONT SCREEN WITH TOP TINT £150
GENUINE SAFF FRONT AMBER £65 PAIR
4X4 BONNETS £110
SAPPHIRE COSWORTH BLUE FRONT BUMPER £225
ESCORT COSWORTH MINT HEADLIGHTS £80 ono
JACKING COVERS £17.50 EACH PLUS POST
SAPPHIRE clear front indicators £30
3DR WHALE TAILS £225
3dr cosworth skirts NO ARCHES genuine £80 pair
PASSENGER SIDE REAR QUARTER 3DR TRIM £65 PLUS POST
3dr Jacking covers £15 each
SAPPHIRE REAR SPOILERS £45
DOORS £45 EACH
BACK BUMPERS FROM £80
SIDE SHIRTS WITHOUT JACKING COVERS £65 WITH COVERS £120
INTERIOR (JUST ASK MORE IN STOCK)
WHITE DIALED 3DR CLOCKS £85 PLUS POST
FORD STEREO £35
4X4 SAPPHIRE CLOCKS £45
LEATHER INTERIORS FROM £400
CLOTH INTERIORS FROM £250
3DR INTERIOR FRONT/REAR SEATS £450
CARPETS FROM £45
2WD STEERING WHEELS £100
4X4 STEERING WHEELS £65
SAFF CLOCKS SURROUND £20
L6 ECUs FROM £145
STAGE 3 L6 ECU £185
L8 ECU FROM £250
2WD REAR PARCEL SHELF SPEAKERS £30 PAIR
FOG LIGHT SURROUNDS £25 PAIR
DASHES FROM £45
2WD, 4X4 AND FACE LIFT MODELS
2wd horn push £20
ESCORT COSWORTH REAR CARPETS £40 PAIR
4X4 Saff ecu holder £20
LOCKWOOD WHITE FACED CLOCKS £60
UPRATED FUEL REG £45
REAR ARCH LINERS £60 PAIR
GREEN INJECTORS £125
GREY INJECTORS £150
STAINLESS CONE FILTER COVER £20
ACCELERATOR BRACKET £25
OIL CAP RS TURBO £10
WHITE 7.5 X 17 COMPS WITH RALLY TYRES £750
BLACK 7.5 X 17 COMPS WITH TYRES £750
RED CAM COVER £135
3DR REAR PARCEL SHELF HOLDERS £50 PAIR
3DR REAR STRUT COVERS £45 PAIR
PLASTICS 3DR
RS ECU COVER £75
3DR DASH BIT CRACKED £85
3DR WINDOW COVERS £30 PAIR
MINT 3DR COWLING £45
4X4 BADGES £30
STAINLESS ACTUATOR COVER £15
STAINLESS MAP SENSOR BRACKET £15
BLUE SWEDISH PLENIUM COMPLETE WITH THROTTLE BODY £425
LESS THROTTLE BODY £300
4X4 SHARKTOOTH WHEELS £350
STAINLESS WINDOW SWITCH £10
CONE FILTERS
T34 PIPES
3 BAR MAP SENSORS
ESCORT COSWORTH SUMP GUARD BRACKETS
2WD SUMP £125
ESCORT LOWER SPOILER
T5 GEARBOX TAIL HOUSING
BAILEY PAS BOTTLE £65
WILL POST INTERNATIONALLY AND TAKE PAYPAL AS PAYMENT ALSO
Stage 3 chip
Running a t3 turbo
Dark green injectors
3 bar map sensor
044 fuel pump with new wiring kit fitted
New fuel filter and new fuel pump holder
All the sensors changed
Large air filter
New radiator with uprated fan cut in switch
Big intercooler
AL PARTS AVAILABLE!!!!!!!!!!!!!
THIS CAR WILL BE STRIPPED AND EVERYTHING WILL BE AVAILABLE APART FROM THE WHEELS AS I MAY KEEP THEM.
ENGINE IS SWEET AND BOX IS GOOD
SHELL NEEDS ATTENTION BUT STILL FOR SALE
HAS GOOD LEATHER  SOLD
RS500 COOLER
LARGE CONE FILTER SOLD!!!!!!!!!!!
AMBER REARS AND FRONTS
ETC[/b][/size]
RED 2WD AND 4X4 CAM COVERS FROM £135
T5 FIFTH GEARS £120 EACH
LOCKWOOD WHITE DIALED CLOCKS £55
WHITE DIALED CLOCKS NOT LOCKWOOD £45
BLACK CAM COVER £135
4X4 KONIS £175
SET OF 4 LATTICE WHEELS £225
GENUINE 3 BAR MAP SENSOR £150
ORIGINAL GREEN CAM CVER £145
SWIRL POT £65
RED SAMCO BOOST HOSES £70
ESCORT COSWORTH CAM BELT COVER £85
SET OF 403 GREYS £150
WINDOW SWITCH £17.50
GOOD CARRELLI HEADLIGHTS £60 PAIR
STAGE 3 ECU LEVEL 6 £185
CLEAR INDICATORS £20 PAIR
CLUTCH FORK COVER £20
2WD CAM BELT COVER £55
4X4 WING BADGES VERY GOOD £35
FOG LIGHT SURROUNDS £35
REAR DOOR COVERS £35 PAIR
LEVEL 8 ECU STAGE 1 £275
GOOD MOTORSPORT BLUE HT LEADS £55
2WD PLASTIC HEADER TANK £85
FACE LIFT 4X4 DASH (SMALL CRACK ON TOP) £35
VERY GOOD 3DR HEADLIGHTS £100
T34 SILICON BOOST HOSES £35 EACH
PF09 THROTTLE POSITION SENSORS £75
CONE AIR FILTERS £55
SMALL SWIRL POT £60
10703743_488926994580331_853556640151229
10345534_488405034632527_215449411111943
