Nissern Posted September 27, 2011 Share Posted September 27, 2011 Hei. Ser etter chip + litt små div får å få opp heste antallet Men hvilke hjerne har jeg?Hvordan finner jeg det ut? Det er en 4x4 cosworth.... Takker for svar. Link to comment Share on other sites More sharing options...
hår ball Posted September 27, 2011 Share Posted September 27, 2011 er det en org bil så er det L8 Link to comment Share on other sites More sharing options...
twin turbo Posted September 27, 2011 Share Posted September 27, 2011 http://www.bigturbo.co.uk/ gå inn på ecu typer her så ser du korleis du skiller dei vis du er usikker... kan vere bytta før og... trehjulsykel Link to comment Share on other sites More sharing options...
bige Posted September 27, 2011 Share Posted September 27, 2011 ECU types used in Sierra (RS) Cosworth:All type of Sierra (RS) Cosworth use a Weber Marelli type of ECU (Engine Control Unit or motormanagement) however, these ECU's have changed over the years as demands grew and computer technology improved.Although, as far as known, all ECU's use the same connector pin-out (und thus can be electrically interchanged) one can not use for instance the latest ECU on the earliest Cosworth. This is because the ECU is fully "tuned" to the engine characteristics which have dramatically changed over the years. The latest ECU's also use input from several additional sensors which are not available in older models.Here is an overview of ECU's used and how to recognise them: Level 1:Used on the RWD hatchback RS Cosworth, has 64Kb of memory. Can be recognised by the mounting flange on the front face and a yellow CO adjustment screw.Level 6:Used on the RWD sedan (RS) Cosworth, has the same capabilities as the level 1 model but uses totally different electronics. That's why Level 1 and Level 6 chips can not be interchanged.Can be recognised by the mounting flange on the front face (like the Level 1) and a white CO adjustment screw (Level 1 has a yellow one).Level 8:Used on the 4x4 sedan (RS) Cosworth, has twice the memory storage capacity (128Kb instead of 64Kb) as Level 1 and Level 6. That's why chips can not be interchanged.Level 8 was available in 2 type since the engine in the 4x4 was available with and without hego-sensor (i.e. with and without catalytic convertor).Can be recognised by not having mounting flanges and a green or red label with WD48.08.The one with the green label and second code IAW048/01 is for the catalytic convertor (US83) model.The one with the red label and second code IAW048/02 is for the non catalytic convertor (15/04) model.It is uncertain if units/chips can be interchanged between red and green types/engines.There are also Weber Marelli P8 (no flanges, white label IAW48/P8) and Ford EECIV (totally different from Weber Marelli, central bolt to hold connector) ECU's around. These are however only intended for use on a Escort RS Cosworth but you might find them in some motorsport Sierra's (RS) Co Link to comment Share on other sites More sharing options...
Cossyman85 Posted September 27, 2011 Share Posted September 27, 2011 er det sierra eller escort? som hår ball sier:Psierra 4x4 cosw er l8, (om ikke bytta). escort heter vel p8? eller noe, (noen må nok rette meg escort kan jeg ikke noe om, hehe) Link to comment Share on other sites More sharing options...
Ron Posted September 27, 2011 Share Posted September 27, 2011 Vingebil = L12WD sedan = L64WD sedan = L8Escort Cosworth = P8 Caution, any attempt to overtake will result in a race! Link to comment Share on other sites More sharing options...
Nissern Posted September 28, 2011 Author Share Posted September 28, 2011 Takker for gode svar =)Ja, det er en Sierra, glemte å nevne det... Link to comment Share on other sites More sharing options...
haakie Posted September 28, 2011 Share Posted September 28, 2011 Stjeler tråden litt passer et 4x4 motornett på en l6 hjerne ? -Sierra Cosworth 89' 2wd Link to comment Share on other sites More sharing options...
a.nilsen Posted September 28, 2011 Share Posted September 28, 2011 Ja. Du må bare bytte om de to ytterste pinnene/ledningene på TPS så er det plugg and play. '78 Ford Escort Mk2 Gp.2 spec. med YB maskinist Link to comment Share on other sites More sharing options...
