vingesvin Posted December 3, 2010 Posted December 3, 2010 (edited) Dear customer We are proud to an ounce in January we will have our cosworth 200 YB alloy blocks ready for marketing , we have been testing them for some time now in drag racing and rally engine with some incredible results , Manufactured from Grainger & Worrall - Super-Cube Machined Castings. Foley Patterns of Kidderminster designed and manufactured the first class casting equipment that is used to produce the ATMsport YB block castings. They aslo do work for the F1 teams, YB Aluminium Cylinder Blocks are tailor finished to meet the individual needs of their customers´ YB Blocks - STD Block Kit Includes: * Any Bore Size between: 90.8mm - 96.0mm * Any Block Deck Height between: 207.5mm(std) - 221.5mm (+14mm) * Steel Main Caps * ARP Main Caps Studs * Special Ductile High Strength Cylinder Liners (Honed to size) * Dowels / Core Plugs / Oil & Water Plugs * Std Head Bolt Machining * 2wd Water Pump Machining * Long-stroke machining & special breather baffle * * Price = £3,600.00 YB Block Options * Piston oil squirt jets x4 (supplied and fitted) * Long Stud kit x10 - Special Deep engagement - Hi-Boost * Tall Block Idler & Cam Belt Kit - 2 Types * Multi-Shim Big Bore Head Gaskets 95-96mm * Std ARP Head Stud Kit For any more infermation or photo's contact sales@atmsport.com Kanskje dette er interessant for noen? Eller om noen vet noe om desse? Dette er IKKE samme blokkene som er solgt av cosworth. Edited December 3, 2010 by vingesvin
JHS Posted December 3, 2010 Posted December 3, 2010 Med ryktet til ATM så ville ikke jeg lagt igjen £3600 hvertfall... Kanskje det er nyovermalt 205 blokk man får?
vingesvin Posted December 3, 2010 Author Posted December 3, 2010 Med ryktet til ATM så ville ikke jeg lagt igjen £3600 hvertfall... Kanskje det er nyovermalt 205 blokk man får? Fortell.
grcossie Posted December 3, 2010 Posted December 3, 2010 Er ikke mangen, som har posetive erfaringer med Atm, de selger deler, som bla er merket 909, uten at de har noe med org 909 deler å gjøre. Kjenner til dårlige kjøp derfra, eneste måten å handle med dem, i følge engelskmenna, er å stikke innom eg virkelig se varen.Man får kjøpt nye alu blokker fra Cosworth også
JHS Posted December 3, 2010 Posted December 3, 2010 Fortell.Ett raskt søk på f.eks. passionford vil fortelle mer enn nok om ATM.
