Dear customer
We are proud to an ounce in January we will have our cosworth 200 YB alloy blocks ready for marketing , we have been testing them for some time now in drag racing and rally engine with some incredible results ,
Manufactured from Grainger & Worrall - Super-Cube Machined Castings. Foley Patterns of Kidderminster designed and manufactured the first class casting equipment that is used to produce the ATMsport YB block castings. They aslo do work for the F1 teams,
YB Aluminium Cylinder Blocks are tailor finished to meet the individual needs of their customers´
YB Blocks - STD Block Kit Includes:
* Any Bore Size between: 90.8mm - 96.0mm
* Any Block Deck Height between: 207.5mm(std) - 221.5mm (+14mm)
* Steel Main Caps
* ARP Main Caps Studs
* Special Ductile High Strength Cylinder Liners (Honed to size)
* Dowels / Core Plugs / Oil & Water Plugs
* Std Head Bolt Machining
* 2wd Water Pump Machining
* Long-stroke machining & special breather baffle
* Price = £3,600.00
YB Block Options
* Piston oil squirt jets x4 (supplied and fitted)
* Long Stud kit x10 - Special Deep engagement - Hi-Boost
* Tall Block Idler & Cam Belt Kit - 2 Types
* Multi-Shim Big Bore Head Gaskets 95-96mm
* Std ARP Head Stud Kit
For any more infermation or photo's contact sales@atmsport.com
Kanskje dette er interessant for noen? Eller om noen vet noe om desse? Dette er IKKE samme blokkene som er solgt av cosworth.
Edited by vingesvin
Med ryktet til ATM så ville ikke jeg lagt igjen £3600 hvertfall... Kanskje det er nyovermalt 205 blokk man får?
Er ikke mangen, som har posetive erfaringer med Atm, de selger deler, som bla er merket 909, uten at de har noe med org 909 deler å gjøre. Kjenner til dårlige kjøp derfra, eneste måten å handle med dem, i følge engelskmenna, er å stikke innom eg virkelig se varen.
Man får kjøpt nye alu blokker fra Cosworth også
