sierraTIC Posted June 19, 2010 Posted June 19, 2010 Ønsker å bytte min combat front fanger i cosworth front fanger til mk1 sierra kan ta mk2 også Våle vestfold 932 920 99
MrFord Posted June 19, 2010 Posted June 19, 2010 (edited) er det fester og sånt på den? Skader? tåkelys?Har i tillfelle en Mk2 fanger Edited June 19, 2010 by MrFord “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”― Jeremy Clarkson
sierraTIC Posted June 20, 2010 Author Posted June 20, 2010 (edited) fangern er HEL ikke noe skader tåkelys og alt er der, Bilde? Edited June 20, 2010 by sierraTIC
MrFord Posted June 20, 2010 Posted June 20, 2010 Kan du legge ut bilde av innvednig i fanger? av festene osv? Sitter på laguna leppe på cossie fangeren forresten “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”― Jeremy Clarkson
sierraTIC Posted June 20, 2010 Author Posted June 20, 2010 (edited) fanger står på bil så gidder ikke ta den av for å ta bilde innvendig er hel og pen UTEN skader. Åssen ser mk2 fanger ut på mk1 ? Edited June 20, 2010 by sierraTIC
HoelRacing Posted June 21, 2010 Posted June 21, 2010 Åssen ser mk2 fanger ut på mk1 ? Sjekk prosjekttråden til "Escort RST WRC". Mener han brukte mk2 fanger på mk1. 92' Ford Sierra Cosworth 4x4
MrFord Posted June 21, 2010 Posted June 21, 2010 (edited) Helt riktig det HoelRacingHåper Escort RST WRC godkjenner bruk av bildene hans. Hvordan er det laga fester inni fangeren da? brukes orginal fester eller er det noe annen patent? Edited June 21, 2010 by MrFord “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”― Jeremy Clarkson
