Mute Posted January 7, 2010 Posted January 7, 2010 (edited) ønsker å kjøpe abs modul med delenr : 98ag2c013cb og abs ventil delenr: 98ag2c286ba treffes på 90966666 Edited January 13, 2010 by Mute Ford Mondeo Ghia X 2004 130hk 5Tronic
mr.cossie Posted January 7, 2010 Posted January 7, 2010 www.finndel.no -91 Sierra Cosworth 4wd, 0-402 12,039 187,5 kmt ,P500.Focus RS-ST.orange/svart hiace. trekkbil www.markisemannen.no
Mute Posted January 7, 2010 Author Posted January 7, 2010 finner ikke noen deler på den siden med det riktige delenr. Ford Mondeo Ghia X 2004 130hk 5Tronic
rattlesnake Posted January 7, 2010 Posted January 7, 2010 ønsker å kjøpe abs modul med delenr : 98ag2c013cb og abs ventil delenr: 98ag2c286ba treffes på 90966666hei jeg har abs sentral fra 3 dør 00 mod..delenummer 98AG-2M10EA Hvis det hjelper deg
Mute Posted January 10, 2010 Author Posted January 10, 2010 nej iflg. Ford her i området så hjelper det ikke. Ford Mondeo Ghia X 2004 130hk 5Tronic
Guest Knallgass Posted February 1, 2010 Posted February 1, 2010 Problem med at lyset er på-hele tiden eller av og til, men ingen feil? Hjelper kanskje lite å bytte modulen da. I too found the thread on RAC forum and took their advice and removed the dash. It really is quite simple, only 3 phillips screws to remove the surround then 4 more to remove dash. Take the cable plug off the back of the dash then remove the back. This is 4 clips around the edge and 2 torx screws. Once the back is removed you can see the printed circuit board. Mine had what looked like a powdery "growth" that was obviosly intermitantly shorting out on the pcb tracks, giving me flashing lights and loss of trip etc. I cleaned it with a small stiff brush and some electrical contact cleaner. I put it back together and hepresto no flashers since. Hope you are suceessfull. There must be a problem with the lacquer on the pcb? Ford must know there is a prob as 100's have written to them according to other forums?
Mute Posted February 1, 2010 Author Posted February 1, 2010 Lyser hele tiden. og feil koden som ford har lest av er at det er brudd i abs sentralen. Ford Mondeo Ghia X 2004 130hk 5Tronic
