derekd Posted September 3, 2009 Posted September 3, 2009 (edited) kan hentes i ringsaker eller sendes tlf99292976 eller pm litt info om den The ECU DATA MONITOR is a device for monitoring the ECU sensors and engine performance. This was designed to give the driver information about the operation of the engine as seen by the actual engine managment sensors. This unit is wired in parallel with the ECU and so does not care which type of ECU or chip is fitted to the car. (Does not support EEC4 cars yet). The display shows real time data of the sensors in numeric and graphical format and also records peak operating data. Data is displayed on a backlit Black on yellow LCD and operation is with two push buttons. The unit continuously monitors sensors and checks for faults as well as user adjustable alarms and when a fault or alarm occurs, an output is energised to drive a lamp or buzzer to warn the driver of possible problems. The user can set alarms for HIGH BOOST, HIGH CHARGE TEMPERATURE, HIGH COOLANT TEMPERATURE, HIGH BATTERY VOLTAGE and LOW BATTERY VOLTAGE. In addition to the monitoring, control of a water injection pump comes as standard. This is controlled by wiring an external relay to drive a pump and the user can adjust all settings required to drive this such as boost pressure and charge temperature. Supplied in a black or gray plastic box or an in dash bezel to replace factory fitted clock Edited September 3, 2009 by derekd
Asil Racing Posted September 3, 2009 Posted September 3, 2009 kanskje dumt spørsmål , men hva er en s e c s monitor ?
derekd Posted September 3, 2009 Author Posted September 3, 2009 (edited) har lagt den inne annonse nå Edited September 3, 2009 by derekd
Cosworth Racing1 Posted September 3, 2009 Posted September 3, 2009 Viser denne en komplett oversikt over alle sensoren på motor og temperatur på f.eks kjølevann? Hvordan er tilkoblingen til dette? Vil det f.eks passe til Pectel-sprut eller..?En prisantydning er også greit siden dette ikke er noe det selges mye av, og få vet hva dette koster.. 2008 VW Transporter 2,5 4motion1991 Sierra Cosworth 4x4
tommy w Posted September 3, 2009 Posted September 3, 2009 Viser denne en komplett oversikt over alle sensoren på motor og temperatur på f.eks kjølevann? Hvordan er tilkoblingen til dette? Vil det f.eks passe til Pectel-sprut eller..?En prisantydning er også greit siden dette ikke er noe det selges mye av, og få vet hva dette koster.. pris i england er £267 inkl vat. dette må vel være veiledende Slik jeg har forstått det så passer denne direkte på L1,L6,L8 og P8 sprut og dermed ikke til pectel. Sierra Cosworth 4x4 Limited Edition 73/700Escort CosworthEscort CosworthFord SVT LightningMB Vito 2013
Cosworth Racing1 Posted September 3, 2009 Posted September 3, 2009 pris i england er £267 inkl vat. dette må vel være veiledende Slik jeg har forstått det så passer denne direkte på L1,L6,L8 og P8 sprut og dermed ikke til pectel. Okei.. Men hvis det skal brukes til original hjerne, hvordan kobles det da? Kan ikke huske at den originale hjernen har noen løse stikk for tilkobling 2008 VW Transporter 2,5 4motion1991 Sierra Cosworth 4x4
tommy w Posted September 3, 2009 Posted September 3, 2009 Okei.. Men hvis det skal brukes til original hjerne, hvordan kobles det da? Kan ikke huske at den originale hjernen har noen løse stikk for tilkobling Det er jeg ikke sikker på, men det er ikke helt usannsynlig at den bare kobles mellom kontakten til hjernen og hjernen. Slik som en piggy-backDette vet kanskje eier mer om. Sierra Cosworth 4x4 Limited Edition 73/700Escort CosworthEscort CosworthFord SVT LightningMB Vito 2013
derekd Posted September 3, 2009 Author Posted September 3, 2009 Det er jeg ikke sikker på, men det er ikke helt usannsynlig at den bare kobles mellom kontakten til hjernen og hjernen. Slik som en piggy-backDette vet kanskje eier mer om. ja det loddes til kontakten til hjernen enkelt
