Ronny Posted May 25, 2009 Posted May 25, 2009 (edited) Ønsker å kjøpe bra startmotor til 2wd cossie, samt store kabelen ifra Batteriet ned til starteren! Pm eller Email.! ronnyoddli@hotmail.com 48290341 Edited May 26, 2009 by Ronny 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++
a.cosworth Posted May 26, 2009 Posted May 26, 2009 Rediger inn TLF nr. som sagt i reglene, er du grei -Arne '03 Silverado, Duramax'11 VW transporter'06 Land Cruiser konebilX'86 Sierra Cos 2wd X'Sierra cos 4x4 X'SVT LightningX...osv...
Ronny Posted May 27, 2009 Author Posted May 27, 2009 Anyone? 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++
Ronny Posted May 31, 2009 Author Posted May 31, 2009 Ønsker å kjøpe bra startmotor til 2wd cossie, samt store kabelen ifra Batteriet ned til starteren! Pm eller Email.! ronnyoddli@hotmail.com 48290341 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++
Fakeworth Posted May 31, 2009 Posted May 31, 2009 Starter finner du på escort mk3 og 4 -93 Sierra Cosworth STV 4x4 X: -94 Escort Cosworth HTT, -94 Escort cosworth T-25, -94 Escort cosworth T-34, 4x -90 Sierra 4x4 Cosworth, -91 Sierra Cosworth 2wd, - 89 Sierra Cosworth 2wd, -88 Sierra Cosworth 2wd -91 Scorpio Cosworth
Ronny Posted May 31, 2009 Author Posted May 31, 2009 (edited) Starter finner du på escort mk3 og 4 Okki! Takker & Bukker! Edited May 31, 2009 by Ronny 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++
