capri-rs Posted January 22, 2009 Share Posted January 22, 2009 (edited) siden forrige kjøper trakk seg og bestilte SQ6 av meg i steden har eg ein T6M tilsalgsleveres med software og tilstandsrapport fra pectel. kun seriøse.ingen" hvor mange hester extra får eg med denne" litt info: 8 ign. outputs12 injectors (høg og lav ohm)13 analoge inputs2 K-type thermocouple2 NTK wideband lambdaopptil 10 PWM outputs denne befinner seg i hylla mi i lag med flere T2 og Sq6 tlf 911 49 555 siden eg bruker 10 min på å skrive "ok" i ein tekstmelding, Gi f..... mvhGeir Edited January 22, 2009 by capri-rs "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
Extreme Posted January 22, 2009 Share Posted January 22, 2009 Har du både t2 och t6? priser,är de nya grejer? www.cosworthclubsweden.se Link to comment Share on other sites More sharing options...
capri-rs Posted January 22, 2009 Author Share Posted January 22, 2009 Har du både t2 och t6? priser,är de nya grejer?skaffer nye T2 og SQ6T6 gikk ut av produksjon for ca 2 år siden,ble erstattet av SQ6 mvhGeir "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
capri-rs Posted February 1, 2009 Author Share Posted February 1, 2009 opp "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
cbp Posted February 1, 2009 Share Posted February 1, 2009 Å dette skal du ha hva for? If NISMO stands for Nissan Motorsports, does HOMO stand for Honda Motorsports??? Link to comment Share on other sites More sharing options...
capri-rs Posted February 1, 2009 Author Share Posted February 1, 2009 Å dette skal du ha hva for?utgangspunkt 10 lapper "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
cbp Posted February 1, 2009 Share Posted February 1, 2009 utgangspunkt 10 lapper Du ville ikke vært interessert å bytte i 4 stk kliss nye Escort Cosworthfelger i eske? Er det med noe ledningsnett? If NISMO stands for Nissan Motorsports, does HOMO stand for Honda Motorsports??? Link to comment Share on other sites More sharing options...
capri-rs Posted February 2, 2009 Author Share Posted February 2, 2009 Du ville ikke vært interessert å bytte i 4 stk kliss nye Escort Cosworthfelger i eske? Er det med noe ledningsnett?penger er ett fint bytte middel kan fikse ledningsnett til samme hvordan du vil ha det har avtale med motorsport wiring i UK mvhGeir "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
capri-rs Posted March 17, 2009 Author Share Posted March 17, 2009 bump "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
capri-rs Posted April 12, 2009 Author Share Posted April 12, 2009 opp "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
