Torp Racing Posted January 17, 2009 Share Posted January 17, 2009 http://www.terra2imports.ca/import-japan121313807939343.htm Link to comment Share on other sites More sharing options...
bige Posted January 17, 2009 Share Posted January 17, 2009 ikke nr 1 --men en AV 500 Link to comment Share on other sites More sharing options...
Furre Posted January 17, 2009 Share Posted January 17, 2009 NR1 er hvit og holder til på bryne.. Men syns det var en litt rar måte og uttrykke CR på? "Compression has been lowered to 7.2kg/cm2 to allow running 40psi of boost, which is common on these engines! " Betyr dette 7.2-1 eller? 88 Sierra cosworth 2-wd Link to comment Share on other sites More sharing options...
cross-box Posted January 17, 2009 Share Posted January 17, 2009 (edited) i salgs annonsen står den ikke som nr 1 200 000 for en 500 + moms er ikke en dårlig pris det Edited January 17, 2009 by cross-box aktiv dyslektiker for oss som liker escort før 1980 Link to comment Share on other sites More sharing options...
Bdt Posted January 17, 2009 Share Posted January 17, 2009 1 of 500 built,for de som ikke har lært seg engelsk ennå betyr dette 1 av 500 som ble bygd.Ikke nr 1.. COS it`s WORTH it! Link to comment Share on other sites More sharing options...
a.nilsen Posted January 17, 2009 Share Posted January 17, 2009 Så da bra ruffsete ut spørr du meg.. Haug med jallamikk. '78 Ford Escort Mk2 Gp.2 spec. med YB maskinist Link to comment Share on other sites More sharing options...
Torp Racing Posted January 18, 2009 Author Share Posted January 18, 2009 1 of 500 built,for de som ikke har lært seg engelsk ennå betyr dette 1 av 500 som ble bygd.Ikke nr 1.. go du Link to comment Share on other sites More sharing options...
Furre Posted January 19, 2009 Share Posted January 19, 2009 Noen som har peil på compen? 88 Sierra cosworth 2-wd Link to comment Share on other sites More sharing options...
Tore_TJ Posted January 22, 2009 Share Posted January 22, 2009 den så noe fæl ut. blasfemi.. Link to comment Share on other sites More sharing options...
