Trenger litt hjelp!
Guest Focus99
Guest Focus99
Hei!
Jeg fikk mail av DIYAutotune, og med min gode engelsk trenger jeg litt hjelp :P
Her er mailen:
I'm going to need a bit of information about this car as I'm not too familiar with European Fords and it's a little difficult for me to find out much about them.
Does this one have an EEC-IV computer, the Ford built one with a 60 pin connector?
If this is the case, does it have a distributor or EDIS? Ford electronics are pretty well documented, but I will need to find out what it is we are dealing with here. If it uses Bosch electronics instead, let me know as I will have some more questions about it. Also, will you be looking to buy a ready made Megasquirt or build one from a kit?
Hjelpen jeg trenger:
Jeg trenger å vite hvilken info han trenger og om noen kan skrive opp det han trenger å vite om min MK1 IS 5dørs.
Etter sånn jeg forstår det har min 2,0 IS Innsprøytning som her han kaller eec-iv? stemmer det?
Min bil er jo da en helt orginal IS uten noen som helst ekstra sensorer å slikt, det skal monteres cosworth råder, stempler og turbo.
Og da vil jeg ha Megasquirt datasprut:)
Tusen takk for all hjelp!!
Mvh
Martin
Edited by Focus99
Your car have a ECC-IV computer with a 60 pin connector. It also have a distrubitor with TFI.
Ikke helt stø i engelsk selv. Men dette er vel ca den infoen han er ute etter.
Legger ut lista med det jeg bestilte første gang fra diyautotune:
Products
2 x Innovate Standalone Gauge Kit w\ LC-1 & G2 Analog Gauge (wb-lcg2-3801) = $578.00 (den ene til en kompis)
1 x EEC-IV Adapter Board kit (PCBv2.0) (EEC4-K) = $67.00
1 x JimStim MegaSquirt Stimulator with Wheel Simulator - Unassembled (jimstim-k) = $65.00
1 x MapDaddy 4 Bar MAP Sensor with Barometric Correction (MapDaddy4) = $65.00
1 x MegaSquirt-II Engine Management System w/PCB3 - UnAssembled Kit (MS230-K) = $247.00
1 x MegaSquirt-I or II Relay Cable (MSRelayCable) = $70.00
1 x MegaSquirt Tuning Cable (DB9 Straight Thru) (TuneCable6) = $5.50
1 x GM Boost Control Connector w/ crimp-on pins (GMBoostConn) = $12.00
1 x GM Boost Control Solenoid (GM_BoostSol) = $24.00
1 x PCBv3 and v2.2 -- Boost Control Mod-Kit (MK-Boost) = $7.00
1 x 3/8" NPT Aluminum Weld-On Bung for IAT or CLT Sensor (38NPT-Bung_A) = $9.00
1 x 3/8" NPT Steel Weld-On Bung for IAT or CLT Sensor (38NPT-Bung_S) = $8.00
1 x GM Open Element IAT Sensor with Connector (IATwConn) = $20.00
1 x USB to Serial Adapter - Works with MegaTune! (USB-2920) = $20.00
1 x MegaSquirt EFI (logo1) White Cut Vinyl Decal (inside cut) (d-msefi-win) = $3.00
1 x Anti-Static ESD Protection Wrist Strap (esdstrap) = $5.50
1 x Lead Bending Tool (T-LeadBend) = $5.50
Det jeg glemte og bestille samtidig var motstand som gjør at man kan kjøre med org. vanntempsensor. Er også noen komponenter som er anbefalt å skifte for bruk med TFI. Husker ikke hvilken i farta, men Jerry vet det sikkert. Du trenger selvfølgelig ikke alt det jeg kjøpte. Håper det er til hjelp. Bare spør mer hvist du lurer på noe, så skal jeg gjøre mitt beste for å svare.
-200 Tahoe 5.3 LT, LPG drift.
Youtubekanal
