capri-rs Posted December 2, 2008 Author Posted December 2, 2008 kunne du lagt en retthollt over og sjekket at den var plan.. og det med litt sveist? er den tett? er den tett og plan gir eg deg 450kr... tett er den.hadde ikkje lekkasje ved toppen når eg brukte den.kan sikkert pakke opp og sjekke i løpet av uken "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
FitjarRacing Posted December 3, 2008 Posted December 3, 2008 det hadde vert veldig flott om du hadde giddet og gjort det
capri-rs Posted December 15, 2008 Author Posted December 15, 2008 det hadde vert veldig flott om du hadde giddet og gjort det beklager har heilt glømt det bump foresten "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted December 15, 2008 Author Posted December 15, 2008 besvart "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted December 16, 2008 Author Posted December 16, 2008 Du hast PM besvart "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted January 3, 2009 Author Posted January 3, 2009 det hadde vert veldig flott om du hadde giddet og gjort det ser rimelig plan ut bump forresten "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted January 4, 2009 Author Posted January 4, 2009 bump "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted February 1, 2009 Author Posted February 1, 2009 opp "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted February 3, 2009 Author Posted February 3, 2009 bump "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted March 2, 2009 Author Posted March 2, 2009 oppatt "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted March 4, 2009 Author Posted March 4, 2009 pm sendthar rydda i innboksen var full.kan du sende det en gang til? "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
turbodude Posted March 4, 2009 Posted March 4, 2009 har rydda i innboksen var full.kan du sende det en gang til? pm sendt på nytt
capri-rs Posted March 4, 2009 Author Posted March 4, 2009 (edited) er til sierra .er den største cooleren de lager.3" rør inn og ut er ny ja.pakket opp og står på hylla pris?? kom med eit bra bud Edited March 4, 2009 by capri-rs "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
87RS Posted March 4, 2009 Posted March 4, 2009 ok skal ha til escort.. er til sierra .er den største cooleren de lager.3" rør inn og ut er ny ja.pakket opp og står på hylla pris?? kom med eit bra bud
capri-rs Posted March 9, 2009 Author Posted March 9, 2009 opp "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted March 17, 2009 Author Posted March 17, 2009 bump "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted April 12, 2009 Author Posted April 12, 2009 opp "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
