capri-rs Posted August 20, 2007 Posted August 20, 2007 ønsker å kjøpe fuelral til 4x4 cosworth.trenger også dynamofeste til 2wd cossie. tlf 911 49 555 "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted August 28, 2007 Author Posted August 28, 2007 oppatt "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
Guest Lars Wenås Posted August 28, 2007 Posted August 28, 2007 oppattHar ny 4x4 fuelrail chromma:) Blaank!
capri-rs Posted August 30, 2007 Author Posted August 30, 2007 Har ny 4x4 fuelrail chromma:) Blaank!Pris??? "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted September 1, 2007 Author Posted September 1, 2007 1000 er betalt til den prisen tenkte meir på 250 kr "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
bcLars1 Posted September 1, 2007 Posted September 1, 2007 har ett dynamofeste liggende,skal være til cosworth men veit ikke om det er 2wd elr 4wd. hvordan ser jeg det??
capri-rs Posted September 2, 2007 Author Posted September 2, 2007 har ett dynamofeste liggende,skal være til cosworth men veit ikke om det er 2wd elr 4wd. hvordan ser jeg det??send ett bilde.så lenge det ikke er til poly-v reim er det ok "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
bcLars1 Posted September 3, 2007 Posted September 3, 2007 da må jeg ha ett mobil nr jeg kan sende bilde på mms til.... mvh Stian send ett bilde.så lenge det ikke er til poly-v reim er det ok
capri-rs Posted September 3, 2007 Author Posted September 3, 2007 sjå fyrste posten!! "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
capri-rs Posted October 2, 2007 Author Posted October 2, 2007 da må jeg ha ett mobil nr jeg kan sende bilde på mms til.... mvh Stian oppattte for deg "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
