Guest Mr.Escort Posted December 2, 2004 Posted December 2, 2004 deilig:) men jeg har fått dilla på smurfedrops....blitt helt hekta
Mark1 Posted December 3, 2004 Posted December 3, 2004 purr WWW.NorskEscortRegister.Net Escort Mk1/Mk2 register
Guest cossieboy77 Posted December 3, 2004 Posted December 3, 2004 Her er den nye 2005 Ford Mondeo Delivery.....
Guest TA-Racing Posted December 3, 2004 Posted December 3, 2004 Cossieboy77: Mitt forsøk,ble ikke så bra men.
Tombra Posted December 4, 2004 Posted December 4, 2004 Nå ble det i overkant mange strøkene biler her.Det må endres på: Noen som har en kur mot "må-nesten-fixe-dette-med-det-samme" syndromet? Escort RS Turbo Mondeo 4x4 Capri MK3 GT4 Pajero 4x4 Dynapac F141 6WD
Guest Compom Posted December 4, 2004 Posted December 4, 2004 Du kan alltids få litt av mitt "vi-tar-det-imorra"-syndrom, Tombra.
Guest Compom Posted December 7, 2004 Posted December 7, 2004 Dette sysn jeg bare var et utrolig kult bilde!
TurboX Posted December 7, 2004 Posted December 7, 2004 Enig, Compom -TurboX- '91 Sierra IS Turbo *prosjekt* '79 Capri 2.8 *prosjekt* '86 BMW E30 320i *kommende prosjekt* '86 BMW E30 "320i" *kommende prosjekt/delebil*
Guest Compom Posted December 7, 2004 Posted December 7, 2004 Du har ikke tallene på Reyland-cossien med vogna etter også vel, TurboX? Gikk jo greit unna da også, kommer jag ihåg...
TurboX Posted December 7, 2004 Posted December 7, 2004 Kadett Cosworth -TurboX- '91 Sierra IS Turbo *prosjekt* '79 Capri 2.8 *prosjekt* '86 BMW E30 320i *kommende prosjekt* '86 BMW E30 "320i" *kommende prosjekt/delebil*
TurboX Posted December 7, 2004 Posted December 7, 2004 Joda... Reyland Escort CosworthProbably the most famous of all the Reyland vehicles, Martin's Escort Cosworth holds the top speed record for the badged Cosworth vehicles at 194.7mph. This incredible vehicle also holds the Guinness World Record for the fastest caravan tow at 128.8mph. Martin Hadlands Specification ENGINE:Reyland induction kitTurbo Dynamics GT35 hybrid turbo chargerReyland custom spec camsRoller barrel throttle inlet manifold with 8 siamese grey injectorsReyland spec modified cylinder head and valvesMillington diamond alloy blockReyland spec bottom endWinged sumpPace external oil pumpReyland external wastegateReyland exhaust manifoldMongoose exhaust systemPectel T6 managementMapped by Ahmed Bayjoo on SCS' Dyno TRANSMISSION: Quaife ATB front diff in Ford Motorsport thick wall casing7" ZF plated rear diff in modified casing & alloy diff guardR&D 6-speed straight cut gearboxLightened flywheel with twin plate clutchReyland hydraulic clutch conversion CHASSIS: 8.5x18" Compomotive MO alloys with 235/40 Yokohama tyres10" 485 lb front springs on negative camber strut bodies with Bilstein tarmac inserts Poly bushed 29mm front rollbar mounting through footwell and TCAsRose-jointed front top mounts12" 180 lb rear springs on Bilstein gravel shocksPoly rear beam bushesBrembo eight-pot front calipers with 385mm discsBrembo four-pot rear calipers with 355mm discsAeroquip brakelinesAP brake-proportioning valveHydraulic fly-off handbrakeReyland electric power steering conversion (pump mounted behind passenger foot rest) INTERIOR: Full multi-point weld-in roll cageRecaro SPa Kevlar seats with TRS five-point harnessesStack Tach TimerElliot boost gaugeR&D gear knobCentre console, rear seats & carpet removedCarbon dash panelSPA digital fuel pressure/water temp gaugeSPA digital oil pressure/ oil temp gaugeATL fuel gaugeSPA digital boost/charge air temp gaugeElectronic boost control switchFlick switches for fuel pumps ABS and fans (with override)Pectel MonitorElectric windows, central locking, door/quarter trims and head lining all remain fitted BODY: Twin headlamp conversionBonnet secured with bonnet pinsFord Motorsport door mirrorsFront foglamps replaced with RS500 grillsSeam-welded shellDouble thickness footwells and flitchesAircraft type fuel filler fittedRepsol-style 'REYLAND' painted livery Martin Hadlands Stats 0-60 in 2.89 s 0-100 in 6.06 s 100-150 in 6.974 s Quarter in 10.66 @ 136.95mph Top Speed.... 194.7mph! -TurboX- '91 Sierra IS Turbo *prosjekt* '79 Capri 2.8 *prosjekt* '86 BMW E30 320i *kommende prosjekt* '86 BMW E30 "320i" *kommende prosjekt/delebil*
TurboX Posted December 7, 2004 Posted December 7, 2004 Escort'en dro vogna i 128.8 mph.. -TurboX- '91 Sierra IS Turbo *prosjekt* '79 Capri 2.8 *prosjekt* '86 BMW E30 320i *kommende prosjekt* '86 BMW E30 "320i" *kommende prosjekt/delebil*
Guest Compom Posted December 7, 2004 Posted December 7, 2004 Hehehe!! Synd den ble biter den der asså...
TurboX Posted December 7, 2004 Posted December 7, 2004 Yes, det er det.. men noen godbiter finnes enda da... -TurboX- '91 Sierra IS Turbo *prosjekt* '79 Capri 2.8 *prosjekt* '86 BMW E30 320i *kommende prosjekt* '86 BMW E30 "320i" *kommende prosjekt/delebil*
TurboX Posted December 7, 2004 Posted December 7, 2004 sedan Din? var fin i alle fall -TurboX- '91 Sierra IS Turbo *prosjekt* '79 Capri 2.8 *prosjekt* '86 BMW E30 320i *kommende prosjekt* '86 BMW E30 "320i" *kommende prosjekt/delebil*
hugoh Posted December 8, 2004 Posted December 8, 2004 hm...mye snærtne biler her legger ut et av min fra tidl. i år så får jeg komme sterkere tilbake når jeg er ferdig med utsmykkningen av bilen.. Mvh. Hugo H. Ford sierra 2.0l (Type Ludo.) Ford sierra 1.6l (Type vinterbil racing putt putt !solgt!) Ford sierra P-100 (kommer til meg snart delvis kanselert dessverre) Ford sierra sedan doch 1990 mod (solgt)
Anders Posted December 8, 2004 Author Posted December 8, 2004 Bilen min den dagen jeg kjøpte den.. mann kunne dytte fram hjula frem og tilbake noen cm.. Ford Sierra 3 dørs 86mod Cosworth (Prosjekt)Ford Taunus 17m Super 65mod (Reservetralle) BMW m3 coupe e36 (Sladdekasse)BMW 523i e39 (Brukstralle)
Guest thorbis Posted December 8, 2004 Posted December 8, 2004 sorry ikke min men veit hvem som eier den
Guest JvhCossie Posted December 10, 2004 Posted December 10, 2004 Ut på tur aldri sur.... Var endel som fikk store øyne når de så denne... Det fikk sjåføren himself også når han fant ut at tanken var nesten brukt opp fra Nebbenes (Eidsvoll) og til Elverum....
Guest JvhCossie Posted December 10, 2004 Posted December 10, 2004 Kan også legge til at jeg kjørte på vålerbanen og kom hjem igjen uten problemer
D.Toft Posted December 10, 2004 Posted December 10, 2004 selvfølgelig gjorde du det, du kjørte jo FORD :) hehe
