cross-box Posted January 15, 2007 Share Posted January 15, 2007 aktiv dyslektiker for oss som liker escort før 1980 Link to comment Share on other sites More sharing options...
d-link Posted January 16, 2007 Share Posted January 16, 2007 Denne filmen så jeg for en stund siden på youtube, stilig animasjon Prøvde å lete opp noe info om motoren da jeg ikke kjenner igjen den som er i filmen fra noe Ford jeg har sett tidligere. Fant ikke noe særlig info på nettet heller. Noen som vet noe? [-] Ford Escort RS Turbo S2 - Prosjektbil - 1.6 CVH EFi, Koni, Cobra, Piper 285T2, Deflex, AP Racing, Megasquirt II v3.0, 2,5" Mongoose, Radtec Intercooler, Escos dyser, Cossiebremser, T3 .48 eksos, 7,4:1 cr, Mintex, Lockheed, Toad CarAlarm, AutoGauge, HKS, Innovate Motorsports, SFS Silicone hoses, OMP, 9mm core plug wire [-] Ford Sierra 2.0iS - Bruksbil - kent cam FR34 Link to comment Share on other sites More sharing options...
fiesta_xr2i Posted January 16, 2007 Share Posted January 16, 2007 ikke ventil låseklips .... å reg kjede ?? hva slags ohc ford motor? 2012 Focus 1.0 Ecoboost Stv 125 hk X 2004 Focus ST 170 Imperial Blue X 87/91 sierra cosworth 4x4 stage 3 X 01 mondeo 2,0 tdi stv 115hk X 92 fiesta xr2i 1,8 16v (RS1800) X 88 sierra 2,0 sedan X 90 sierra 2,0i combi Link to comment Share on other sites More sharing options...
Guest Erik Braseth Posted January 16, 2007 Share Posted January 16, 2007 http://en.wikipedia.org/wiki/Ford_HCS_engine HCS In 1988 the engine was revised once again to meet with tightening European emissons legislation and the requirement to use unleaded fuel. The redesign included an all-new cylinder head with hardenened valve inserts, reshaped combustion chambers, and a fully electronic, distributorless ignition system. The engine was renamed the Ford HCS (High Compression Swirl). It first appeared on the Ford Escort, then was later used on the third generation Ford Fiesta. https://www.burtonpower.com/technical/tt_kent.html Link to comment Share on other sites More sharing options...
focusst Posted January 17, 2007 Share Posted January 17, 2007 http://en.wikipedia.org/wiki/Ford_HCS_enginehttps://www.burtonpower.com/technical/tt_kent.htmlDet er nok en annen motor, selv om navnet er det samme. Motoren du mener er en støtstangmotor, opprinnelig fra 50 tallet, revidert x antall ganger. Navn som Kent, HCS og Endura E har blitt brukt på de forskjellige versjonene. Siste utgave satt vel i KAMotoren i filmen ligna veldig på Duratec- et eller annet, som sitter i enkelte nye Fiesta, og i SportKA/ StreetKA. Egentlig en motor som har vært brukt i Sør Afrika hvis jeg ikke husker feil. Ford og motornavn er et kapittel for seg. Nå heter alle bensinmotorer Duratec, samme var det med Zetec tidligere. Mange motorer som f.eks Zetec SE fra Fiesta/Focus har bare fått nytt navn I4 som også filmmotoren ble kalt, brukes også på DOHC 8 V motoren i Sierra/Scorpio, og på 1,8/2,0 16 V i Mondeo 01-. Navnet skjemmer ingen Over til fienden... Link to comment Share on other sites More sharing options...
