Maarius Posted November 12, 2006 Posted November 12, 2006 Lurer bare på om noen har mer informasjon om Sierra XR8 som kom med V8 motor, ble vel produsert i 250 eksemplarer i afrika mener jeg og huske.... Hadde vært moro og fått tak i en sånn
Velde Posted November 12, 2006 Posted November 12, 2006 BackgroundBuilt in South Africa 1984 by Ford South Africa (F.S.A.) Built to support homologation for local saloon car racing, only 250 were built. SpecificationsAxle, rearType: Centrally located hypoid differential assembly with independant open drive shafts Ratio: 3.5:1 Capacity (litres): 1.5 BrakesDescription: Hydraulic - dual line - servo assisted Front type: Ventilated discs with self adjusting sliding caliper Disc diameter (mm): 280.0 Rear type: Disc brakes Disc diameter (mm): 270.0 ClutchType: Cable operated, self adjusting, with single dry plate Diameter (mm): 255 Total frictional area (cm2): 284 Release bearing: Pre-lubricated Cooling systemType: No loss system Capacity (litres): 12 Radiator type: Pressurized fluid circulation Fan: Two electric fans, 11 blades each, diameter 305 mm Drive lineType: One piece articulated Propeller shaft number: 1 Universal joints (front & rear): Needle roller Electrical systemBattery: 440 A/75 RC low maintenance polypropylene Alternator: 60 A Ignition: New breakerless, thick film module EngineType: V8 cylinder OHV Bore and stroke (mm): 101.6 x 76.2 Displacement (cm3): 4942 Output (kW at r/min, SABS): 150.0 @ 4800 Torque (Nm at r/min, SABS): 330.0 @ 3400 Compression ratio: 9.0:1 Fuel systemFuel pump: Mechanical Carburettor: Ford/Holley 4 venturi Choke: Auto choke Fuel filter: Gauze screen in pump Air cleaner: Replaceable dry paper element Tank capacity (litres): 60.0 LubricationEngine: Full pressure feed to main, big end and camshaft bearings Crankcase capacity (litres): 7.0 Oil cooler: Oil to air type SuspensionFront: type: Independent McPherson struts description: McPherson strut front suspension with 15 mm static scrub radius, forged TCA and rearward mounted 24 mm stabiliser bar and parallel front spring design Rear: type: Independent semi-trailing arms description: Frame mounted semi trailing arm and IRS with variable rate coil springs, including rear stabiliser bar SteeringType: Rack and pinion Steering wheel diameter (mm): 382 Turning circle (kerb to kerb, m): 10.00 Ratio: 19.88:1 Transmission, manualType: Manual gearshift Synchromesh: 5 forward gears Ratios: 1st 2.95, 2nd 1.94, 3rd 1.34, 4th 1.00, 5th 073, reverse 2.76 Capacity (litres): 1.9 WheelsType: Cast aluminium Size: 6.0J x 15 TyresStandard: 195/60 VR 15 Steel belt radial ply MeasurementsWeight (kg): total 1279 (front 683, rear 596), payload 400, total weight 1679 Wheelbase (mm): 2608 Rear track (mm): 1468 Front track (mm): 1452 Height (mm): 1406 Length (mm): 4425 Width (mm): 1725 Changed componentsITEM SOURCE REMARKS Radiator grille Unique F.S.A Source: Trek Plastics Front body crossmember Unique F.S.A Front & rear suspension crossmember - " - Reworked standard component Rear suspension arms - " - Reworked standard component Engine - " - Ford U.S. sourced, 302 cid V8. Build code EX-303, as Mustang minus emissions, power steering and airconditioning. Uses unique camshaft, water pump and carburettor (Holley 780 cfm) Radiator Unique F.S.A. European vendor SERK UK sourced Radiator support Unique F.S.A. Cooling fans Two Granada, with air conditioner, fans Exhaust system - " - Manufactured by Bosal, including engine manifolds Clutch cable - " - Low friction design, manufactured by Repco Clutch and transmission Ford U.S. Carryover 1984 Mustang. Transmission - Borg Wagner T5G (Ford Part No. E3ZR-7003-CA) Driveshaft Unique F.S.A Rear axle (Differential) - " - As used in F.S.A. Granada, 3.5:1 ratio, with new rear and uprated side shafts Axle shafts - " - Granada C.V. joints with new shafts Stub axles - outer - " - To suit Sierra hubs and Granada C.V. joints Brakes - Front European vendor AP Racing - Leamington Spa sourced, four pot caliper type Brakes - Rear - " - A Teves Germany-sourced Alternator and regulator Ford U.S. Part No's: Alt E12F-10300-CA, Reg E2PF-10316-BA Wheels Unique F.S.A. European Vendor Ronal wheels - Germany-sourced, Ford Part No. 84BC-1007-AA
D.Toft Posted November 12, 2006 Posted November 12, 2006 vet om en i norge, uten skilt.. den ble tatt inn til england fra sørafrika, og regget der, det kostet ca 80tusen.. så ble den fraktet fra england til norge, og nå står den trygt i en garasje.. A.S Norge skal ha 88 tusen for å gi eieren norske skilter.. den er tilsalgs for rett pris og rett mann... har snakket en del med eieren..
Bewnie Posted November 13, 2006 Posted November 13, 2006 (edited) åååååå... fett. Har så lyst å begynne på ett sånt prosjekt. Må være så sykt grovt å eie noe slikt:) Men ja.. har hørt at det ikke er noe spesielt med den motoren. Skal vist komme fra en eller annen Lincoln. Mercury tror jeg det var den het. Edited November 13, 2006 by Bewnie <!--fonto:Comic Sans Ms--><span style="font-family:Comic Sans Ms"><!--/fonto--><!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo--><!--coloro:#3333ff--><span style="color:#3333ff"><!--/coloro-->-86 Sierra xr4x4 2.8i - Momo Tuner Ratt - Gule Koni - Sparco tårnstag - Custom Green - Shortshift - Recaro. SOLGT<!--colorc--></span><!--/colorc-->Jobbet på Ford, med Ford:)<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
Guest Sierraxr4x4 Posted November 15, 2006 Posted November 15, 2006 må si meg enig med Bewnie, detta hadde vøre prosjekt å starta på dette,
RsturboS2 Posted November 15, 2006 Posted November 15, 2006 er det ikke en som er inne på og bygge noe slikher inne dah? mener jeg leste en tråd om dette? eller? Profesjonell rotekoppp ute på bedringens veg men får alltid motorstopp.I got Adhd whats your excuse ?
D.Toft Posted November 15, 2006 Posted November 15, 2006 stemmer, var meg det, har motor ag alt på hånd, men ikke plass å stå blir MYE å bygge om...
