Guest Tordarn Posted September 19, 2006 Share Posted September 19, 2006 satte på k&n filter på dochen min, går fint å kjøre, men stopper på lave turtall. hva er problemet? :S hehe Link to comment Share on other sites More sharing options...
Tommelom Posted September 19, 2006 Share Posted September 19, 2006 For mye luft? [-] 98 BMW 520 IA [x] 90 Sierra 2.0 DOHC <--- Prosjekt [x] 85 Nissan Micra 1.0 Link to comment Share on other sites More sharing options...
Cossiman Posted September 19, 2006 Share Posted September 19, 2006 skjekka lmm ?? den lange tingen som sitter på luft inntaket Present : Ford Mondeo Stv 2000 mod Ford Sierra RS Cosworth 1991 mod Past : Ford Sierra Sedan 1988 mod Link to comment Share on other sites More sharing options...
Guest Tordarn Posted September 19, 2006 Share Posted September 19, 2006 sikkert for mye luft... Link to comment Share on other sites More sharing options...
Guest zr50sl Posted September 20, 2006 Share Posted September 20, 2006 NEI ikke for mye luft, hvor har du montert filtret hen? Link to comment Share on other sites More sharing options...
morty999 Posted September 20, 2006 Share Posted September 20, 2006 dohc har da ALDRI hatt LMM... det er en tomgangsregulator.. du har ikke glemt den? Link to comment Share on other sites More sharing options...
Cossiman Posted September 20, 2006 Share Posted September 20, 2006 dohc har da ALDRI hatt LMM... det er en tomgangsregulator.. du har ikke glemt den?stemmer det morty men det vi er enige om er at det er den tingen som sitter på røret Present : Ford Mondeo Stv 2000 mod Ford Sierra RS Cosworth 1991 mod Past : Ford Sierra Sedan 1988 mod Link to comment Share on other sites More sharing options...
Guest Tordarn Posted September 20, 2006 Share Posted September 20, 2006 den er forsatt på ja... satte på det som fulgte med.. slik overgang.. og slanger.. 2 slanger som går fra den og inn på filteret.. Link to comment Share on other sites More sharing options...
Cossiman Posted September 20, 2006 Share Posted September 20, 2006 prøv å dra av ledningen på tomgangsregulatoren og se om det blir noe forskjell Present : Ford Mondeo Stv 2000 mod Ford Sierra RS Cosworth 1991 mod Past : Ford Sierra Sedan 1988 mod Link to comment Share on other sites More sharing options...
Guest sierraman Posted September 20, 2006 Share Posted September 20, 2006 motoren får da mye varmere luft med knfilter, filteret suger jo varm luft rett ved motoren. men har du innebygget filter får du kald luft. Link to comment Share on other sites More sharing options...
Cossiman Posted September 20, 2006 Share Posted September 20, 2006 motoren får da mye varmere luft med knfilter, filteret suger jo varm luft rett ved motoren. men har du innebygget filter får du kald luft.ikke tilfelle jeg kjøre med knfilter på dohcen min å det går fint, mange andre som gjør det, kunne sikkert gått bedre hadde den sugd kald luft da Present : Ford Mondeo Stv 2000 mod Ford Sierra RS Cosworth 1991 mod Past : Ford Sierra Sedan 1988 mod Link to comment Share on other sites More sharing options...
Guest Tordarn Posted September 20, 2006 Share Posted September 20, 2006 kanskje prøve å flytte filteret lengst unna motorn.. Link to comment Share on other sites More sharing options...
Cossiman Posted September 20, 2006 Share Posted September 20, 2006 kanskje prøve å flytte filteret lengst unna motorn..men prøv det jeg sa ang Tomgangsreg Present : Ford Mondeo Stv 2000 mod Ford Sierra RS Cosworth 1991 mod Past : Ford Sierra Sedan 1988 mod Link to comment Share on other sites More sharing options...
Guest Tordarn Posted September 20, 2006 Share Posted September 20, 2006 jaja, veit Link to comment Share on other sites More sharing options...
cossie_storm Posted September 20, 2006 Share Posted September 20, 2006 får den mer luft, så øker tomgang også, til et vist punkt da.ingen lekasjer? gjort noe annet? Cosworth 88 sedan prosjekt-klar 05-06-07-08 jajaSierra med scorpio cosworth motor 90 mod Link to comment Share on other sites More sharing options...
Guest Tordarn Posted September 20, 2006 Share Posted September 20, 2006 nei, har bare fjerna luftfilteret og det røret og satt på nye slanger og klemmer... går nå to slanger fra tomgangsregulatoren og til filteret... Link to comment Share on other sites More sharing options...
Guest Tordarn Posted November 6, 2006 Share Posted November 6, 2006 er i orden nå da;) takk for hjelp =) Link to comment Share on other sites More sharing options...
Leo Posted November 10, 2006 Share Posted November 10, 2006 Hva var galt? Bilmekaniker / tekniker01' Honda VTR SP-195' Frosk stv. 2,0 DOHCA BE (før 19.01.2013) C D Women don't really wanna hear men's opinion, they just wanna hear their opinion in a deeper voice Link to comment Share on other sites More sharing options...
2.0 I Doch Posted November 10, 2006 Share Posted November 10, 2006 Kunne du vært så snill å lagt ut bilder av oppsette ditt? den ekstra slangen på innsuget er og kor du har gjort av tomgangsregulatoren.... Link to comment Share on other sites More sharing options...
twin turbo Posted November 13, 2006 Share Posted November 13, 2006 bra du hjar fått orden på det, det eg stusset på var at du sa at begge slangene fra tomgangventil gjekk tilbake til filter og det kan ikkje stemme eller??? trehjulsykel Link to comment Share on other sites More sharing options...
Guest Tordarn Posted November 24, 2006 Share Posted November 24, 2006 kan fikse bilder... Link to comment Share on other sites More sharing options...
2.0 I Doch Posted November 24, 2006 Share Posted November 24, 2006 Flott Link to comment Share on other sites More sharing options...
vinge87 Posted November 24, 2006 Share Posted November 24, 2006 dohc har da ALDRI hatt LMM... det er en tomgangsregulator.. du har ikke glemt den? tenk deg godt om nå, er dette riktig? nei Bruksbil: 2005 E-61 Bmw 535dat M-SportUnder bygging: Escort F-40 4x4 1Uzfe Twin Efr 6258 WRC understell, Quaife Seq q-69 + masse grommt På passionford Dette forumet mangler styring...... Link to comment Share on other sites More sharing options...
møffe Posted November 25, 2006 Share Posted November 25, 2006 en DOHC motor med inj har en mapsensor i stedet for en LMM. hvilken model mener du der har LMM std af dohc modellerne? Link to comment Share on other sites More sharing options...
ford-racing Posted November 25, 2006 Share Posted November 25, 2006 tenk deg godt om nå, er dette riktig? nei er nok ikke mange dohc(sierra 8v) som har lmm gutt, her er det en map sensor, likt som på cosworth`en. så tenkt deg godt om nå, sierra dohc med LMM ------NEI "Don`t find fault, find a remedy; anybody can complain" ~Henry Ford Link to comment Share on other sites More sharing options...
