Tommelom Posted July 21, 2006 Share Posted July 21, 2006 Passer dempere fra en Sierra Cosworth 4X4(88-89 mod) over på min Sierra(90 mod combi)? Isåfall, vil det ha noe for seg å bytte? Er cosworth demperne lavere, stivere? [-] 98 BMW 520 IA [x] 90 Sierra 2.0 DOHC <--- Prosjekt [x] 85 Nissan Micra 1.0 Link to comment Share on other sites More sharing options...
møffe Posted July 21, 2006 Share Posted July 21, 2006 nej de passer ikke. kun hvis din combi er en 4x4 dohc Link to comment Share on other sites More sharing options...
Tommelom Posted July 21, 2006 Author Share Posted July 21, 2006 Er dohc, men ikke 4X4... [-] 98 BMW 520 IA [x] 90 Sierra 2.0 DOHC <--- Prosjekt [x] 85 Nissan Micra 1.0 Link to comment Share on other sites More sharing options...
lyrix Posted July 21, 2006 Share Posted July 21, 2006 4x4 er tykkere,2WD passer. de er 4 cm kortere 08 mondeo titanium X 91 sierra 2,5 turbodiesel prosjekt --> http://www.fordclubn...8-td-til-25-td/76 volvo 242 turbo prosjekt94 pajero GLS 33" dekk <---selges Link to comment Share on other sites More sharing options...
møffe Posted July 22, 2006 Share Posted July 22, 2006 4x4 er tykkere,2WD passer. de er 4 cm kortere 2wd er også tykkere end en std dohc. og 2wd dæmpere kræver 2 wd spindler og bremser Link to comment Share on other sites More sharing options...
Guest JvhCossie Posted July 22, 2006 Share Posted July 22, 2006 Målte litt her om dagen og 4x4 dempere skal gå nedi... men de er 5 cm kortere... Link to comment Share on other sites More sharing options...
Tommelom Posted July 22, 2006 Author Share Posted July 22, 2006 Målte litt her om dagen og 4x4 dempere skal gå nedi... men de er 5 cm kortere... Så du mener det passer? [-] 98 BMW 520 IA [x] 90 Sierra 2.0 DOHC <--- Prosjekt [x] 85 Nissan Micra 1.0 Link to comment Share on other sites More sharing options...
Guest JvhCossie Posted July 22, 2006 Share Posted July 22, 2006 skal prøve dem en dag til uka... Link to comment Share on other sites More sharing options...
Tommelom Posted July 22, 2006 Author Share Posted July 22, 2006 Si ifra da! Har hånda på 4x4 dempere... [-] 98 BMW 520 IA [x] 90 Sierra 2.0 DOHC <--- Prosjekt [x] 85 Nissan Micra 1.0 Link to comment Share on other sites More sharing options...
Guest Ford Gnomen Posted July 22, 2006 Share Posted July 22, 2006 4x4 er 51mm dia. og 2wd er 46mm. Link to comment Share on other sites More sharing options...
Guest zr50sl Posted July 23, 2006 Share Posted July 23, 2006 (edited) 2wd cosworth dempere passer rett i spindla forran på std sierra, bake passer dem oxo MEN da må d bygges litt om, dvs borre større hull i selve demper feste på brua fra 10 mm til 12 mm, eller du kan få pressa inn ei hylse på 12mm ytter diameter 10mm inner diameter i dempern så kan du bruke samme bolten som før til std dempern, MEN må oxo huske å legge stopp skiver på hver side av dempern da cosworth dempera er smalere i innfestninga nede enn std sierra. Dette har jeg gjort selv å ærfart å det funker helt topp Edited July 23, 2006 by zr50sl Link to comment Share on other sites More sharing options...
lyrix Posted July 23, 2006 Share Posted July 23, 2006 (edited) når jeg hadde gule koni fra 2wd måtte jeg kutte vekk fjærskållen på yttersiden for at ikke 17" dekkene skulle ta borti, vart bra høyde da jeg hadde 40mm senkesett og demperne er ca 40mm lavere Edited July 23, 2006 by lyrix 08 mondeo titanium X 91 sierra 2,5 turbodiesel prosjekt --> http://www.fordclubn...8-td-til-25-td/76 volvo 242 turbo prosjekt94 pajero GLS 33" dekk <---selges Link to comment Share on other sites More sharing options...
