L&D Posted August 13, 2006 Author Share Posted August 13, 2006 kom med et bud så blir vi sikkert enig... -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
Count Posted August 14, 2006 Share Posted August 14, 2006 150, putt den i ei norgespakke som jeg betaler. Så liten som råd. Hehe... 12m Super 24v Cosworth Prosjektet mitt Link to comment Share on other sites More sharing options...
Count Posted August 14, 2006 Share Posted August 14, 2006 har du forresten den lista som er under lyktene og over framfanger'n? hel og fin? 12m Super 24v Cosworth Prosjektet mitt Link to comment Share on other sites More sharing options...
Peet Posted August 14, 2006 Share Posted August 14, 2006 fjørene bak??? Link to comment Share on other sites More sharing options...
L&D Posted August 15, 2006 Author Share Posted August 15, 2006 150+frakt er greit for speedo wireTror den listen var hel og fin, men skal sjekke før jeg lover noe... -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
L&D Posted August 15, 2006 Author Share Posted August 15, 2006 fjørene bak??? Jepp har de... Har ikke høgget den ferdig ennå siden bukken er nede for telling fortiden:-( -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
Guest mr_doodee Posted August 15, 2006 Share Posted August 15, 2006 varmeapparatradiator?pris? Link to comment Share on other sites More sharing options...
L&D Posted August 16, 2006 Author Share Posted August 16, 2006 vet ikke helt tilstanden på denne, det surkler fælt i den når motoren får temperatur... -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
L&D Posted August 16, 2006 Author Share Posted August 16, 2006 så på den listen mellom fangeren og lyktene, den så forholdsvis hel ut, men det ene klipsfestet var knekt og paknings listen som ligger ned mot fangeren var litt dårlig... ellers hel...Angående speedo wiren, du sa øvre del??? den så ikke delt ut??? -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
Guest Ed_Hunter Posted August 20, 2006 Share Posted August 20, 2006 Kunne trengt girkassen jeg, hvis du vil selge den. I så fall, er den tight og fin? Pris? Link to comment Share on other sites More sharing options...
L&D Posted August 22, 2006 Author Share Posted August 22, 2006 Har ikke kjørt bilen mer enn 2-3 km så jeg er ikke sikker på hvor bra kassen er... den virker i hvertfall... -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
Peder`n Posted August 22, 2006 Share Posted August 22, 2006 Og jeg trenger Traversen...Men siden bokken din ikke er i form så blir vel det vanskelig? Peder Link to comment Share on other sites More sharing options...
L&D Posted August 22, 2006 Author Share Posted August 22, 2006 Traversen til motor eller gir? har planer om å løfte ut motor og gir snart... -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
Peder`n Posted August 22, 2006 Share Posted August 22, 2006 Ja...så var det meg og navna på dissa delene da ...Jeg mener den tverrliggern bak som har di store foringene i... Peder Link to comment Share on other sites More sharing options...
Count Posted August 31, 2006 Share Posted August 31, 2006 så på den listen mellom fangeren og lyktene, den så forholdsvis hel ut, men det ene klipsfestet var knekt og paknings listen som ligger ned mot fangeren var litt dårlig... ellers hel...Angående speedo wiren, du sa øvre del??? den så ikke delt ut???Ok, da trenger jeg ikke den lista..Den er delt jo, hvis du ikke har automat. Og det har du jo ikke, hehe...Den er delt nede ved torpedoveggen, under batteriet liksom. Skrudd sammen. 12m Super 24v Cosworth Prosjektet mitt Link to comment Share on other sites More sharing options...
L&D Posted August 31, 2006 Author Share Posted August 31, 2006 Helt nede? fant ikke noe kobling i motor rommet, men har heller ikke fått den av girkassen (var ikke så lett å komme til med segaring-tangen pga girtraversen.) Skal prøve å gjøre et nytt forsøk... -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
Guest rioi Posted September 6, 2006 Share Posted September 6, 2006 Hei.Jeg trenger det som er mellom stikkakslingen og klokka på høyre side bak.Bare å skru opp dekselet og ta ut alt.det skal være diverse kuler og noe annet som gjør at dette holder seg på plassTrenger forresten på begge sider av akslingen.Håper du tar deg tid til å fikse dette. Veldig viktig. Skal kjøre cross løp neste helg og har problemer med å skaffe deler Link to comment Share on other sites More sharing options...
L&D Posted September 14, 2006 Author Share Posted September 14, 2006 Nå er bilen vraket;Det jeg tok vare på av deler er:-Dører-Lys-Motor-Drivverk-Bakstilling-Forstilling-Dashbord-Ledningsnett -2013 Ford Focus 1,6i EcoBoost (150hk)x-Ford Mondeo MKII + MKIII, 2x Scorpio, Escort-Ford Anglia 105E-Ford Escort MKII (Bilcross)-Ford Escort MKII (prosjekt) Link to comment Share on other sites More sharing options...
