Åshøgda-raceway Posted February 15, 2006 Share Posted February 15, 2006 er det 3102 som er det riktige delenr på 550 dyser? 2,8 ohms. stemmer det? Link to comment Share on other sites More sharing options...
Guest Komfort Posted February 15, 2006 Share Posted February 15, 2006 er det 3102 som er det riktige delenr på 550 dyser? 2,8 ohms. stemmer det? Siemens 3102Siemens 55lb/h (570ccm/min)Resistance 2.8 Ohms Link to comment Share on other sites More sharing options...
rscosworth Posted February 15, 2006 Share Posted February 15, 2006 hvem har chip til disse og L8? Link to comment Share on other sites More sharing options...
capri-rs Posted February 15, 2006 Share Posted February 15, 2006 grå dyse chip kan brukes med senka bensintrykk. "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you. Link to comment Share on other sites More sharing options...
Åshøgda-raceway Posted February 15, 2006 Author Share Posted February 15, 2006 jeg anntar at jenspeed har chip. Link to comment Share on other sites More sharing options...
rscosworth Posted February 15, 2006 Share Posted February 15, 2006 Part Number 3102 (Commonly known as Siemens 55's) Static Flow Rate w / Gas: 57 lb/hr @ 43.5PSI (300kPa) = 599cc/min Static Flow Rate w /Test Solvent: 55 lb/hr @ 43.5PSI (300kPa) Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (ECM driver modifications required) Pencil beam spray pattern er det flere typer 3102 da? 2,35 og 2,8 ohm? pencil peam sprutmønster er vel uegnet på våre motorer med en dyse midt over skilleveggen i kanalene? Link to comment Share on other sites More sharing options...
Åshøgda-raceway Posted February 15, 2006 Author Share Posted February 15, 2006 (edited) rscosworth: mener du at jeg burde gå for noen andre dyser? Edited February 15, 2006 by Åshøgda-raceway Link to comment Share on other sites More sharing options...
rscosworth Posted February 16, 2006 Share Posted February 16, 2006 nei, jeg hadde også planer om 55'ere... nå har ikke jeg så mye kunnskap om tekniske specs på dyser til at jeg kan skille dem med annet en størrelse - derfor lurte jeg på om noen andre kansje visste bedre. pencil beam betyr jo som oftest noe slikt som smal konsentrert stråle...men det kan jo være at vi må ha akkurat en slik en for ikke blåse for bredt og... for å holde på topic: hvor handler du fra?ser et flowmatchet sett ligger på $240 fra racetronix. syns ikke det var så gal pris for et sett dyser. Link to comment Share on other sites More sharing options...
Åshøgda-raceway Posted February 16, 2006 Author Share Posted February 16, 2006 har bestilt her fiveomotorsport de kostet 334 dollar ferdig sendt. Link to comment Share on other sites More sharing options...
rscosworth Posted February 16, 2006 Share Posted February 16, 2006 ink 25% norsk moms? Link to comment Share on other sites More sharing options...
cosworth540 Posted February 16, 2006 Share Posted February 16, 2006 ink 25% norsk moms? + mva hvis det skal skje i "lovlige" former Link to comment Share on other sites More sharing options...
Åshøgda-raceway Posted February 16, 2006 Author Share Posted February 16, 2006 stemmer. måtte betale 44 dollar i post. blir vel ca 2300kr for dem da. er ik ille det. Link to comment Share on other sites More sharing options...
rscosworth Posted February 16, 2006 Share Posted February 16, 2006 blir nermere 2800 når momsen er betalt... Link to comment Share on other sites More sharing options...
GTD40 Posted February 19, 2006 Share Posted February 19, 2006 Betalte 253 dollar hos racetronix......ca 1680 kr.....henta dem selv i Los Angeles.....;o) Signatur fjernet grunnet størrelse. Signatur kan være på inntil 5 linjer i normal skriftstørrelse, eller bilde/banner-størrelse 100x800 pixler og 75 kb. Link to comment Share on other sites More sharing options...
