RC 45 Posted January 17, 2006 Author Posted January 17, 2006 river bra den der veit du specs? Ikke noe mer enn at det skulle hvere 1000+HK
RS|Stian Posted January 17, 2006 Posted January 17, 2006 Feite mora mi! Var sikker på den skulle dra av rulla der et sekund FordClubNorway.no
d-link Posted January 17, 2006 Posted January 17, 2006 GTR-700 - Stage 3 - Outright drag specifications: Current power: Greater than 1 Megawatt (~1,350 BHP) at over 3.0 Kg/cm2 Current weight: 1,345 Kg (~2,960 lbs) as raced with fuel and driver. Weight increase due to requisite safety equipment. Best result: Best ET of 8.273 and best trap speed of 167.76 mph. Using only 10,500 rpm rev limit (estimated ~1,100 BHP) *: Run done at estimated 66% power potential. Still much more to go, yet! Engine redline: Exceeds 13,000 rpm (Stage 2 was 11,500rpm) Fuel system: Custom 2,000cc injectors (x6) (Stage 2 was 6x 1,750cc) Drive train: Custom uprated drive shafts, front (x2) and rear (x2) Aerodynamics: Custom rear under-tray and diffuser Custom front turbo intake air-ducting Suspension: Modified VeilSide Pro-drag coil over suspension system Interior: Bride Zieg Carbon-Fibre/Kevlar race seat (x1) Weight reduction: Further stripping and weight loss program Wheel rims: BBS Le mans' LM limited edition, forged, (Gold) 18" x 10.5" for drag radial class (x4) Rays Advan RG, forged, (White) 15" x 8" for outright drag slick class (x4) Her er en filmsnutt der den lader rundt 2.5kilo, og er på vei av rulla selv om bilen er stroppa ned til det latterlige http://www.exvitermini.com/movies/jumpoff.mpg Noe av det værste jeg har sett i alle fall [-] Ford Escort RS Turbo S2 - Prosjektbil - 1.6 CVH EFi, Koni, Cobra, Piper 285T2, Deflex, AP Racing, Megasquirt II v3.0, 2,5" Mongoose, Radtec Intercooler, Escos dyser, Cossiebremser, T3 .48 eksos, 7,4:1 cr, Mintex, Lockheed, Toad CarAlarm, AutoGauge, HKS, Innovate Motorsports, SFS Silicone hoses, OMP, 9mm core plug wire [-] Ford Sierra 2.0iS - Bruksbil - kent cam FR34
Denes Racing Posted January 17, 2006 Posted January 17, 2006 Fikk ganske greit med gåsehud av den siste filmen der gett. det der er jo helt ekstremt!!
hår ball Posted January 17, 2006 Posted January 17, 2006 er nokk det sykeste jeg har sett sammen med en amrikaner med twin turbo og greier... husker ikke effekten i farta men det var rimelig villt, spøla bara på rulla, mener jeg fant filmen på forumet her for ei god stund tilbake... var vertfall sykt
Guest Ford_V6 Posted January 18, 2006 Posted January 18, 2006 er nokk det sykeste jeg har sett sammen med en amrikaner med twin turbo og greier... husker ikke effekten i farta men det var rimelig villt, spøla bara på rulla, mener jeg fant filmen på forumet her for ei god stund tilbake... var vertfall sykt Denne du mener?
Guest abn0rmal Posted January 18, 2006 Posted January 18, 2006 Denne du mener? Den filmen funka ikke helt! Slutta midt i klippet mersom...
Guest Ford_V6 Posted January 18, 2006 Posted January 18, 2006 (edited) Den filmen funka ikke helt! Slutta midt i klippet mersom... tror det skjedde noe med opplastinga...skal prøve igjen jeg...evnt se om jeg finner siden den ligger på... Her er den! Edited January 18, 2006 by Ford_V6
hår ball Posted January 18, 2006 Posted January 18, 2006 tror det skjedde noe med opplastinga...skal prøve igjen jeg...evnt se om jeg finner siden den ligger på... Her er den! var denne jeg mente ja... syyyyk bil
Guest Ford_V6 Posted January 18, 2006 Posted January 18, 2006 var denne jeg mente ja... syyyyk bil Den er syk den ja... Står i slutten av klippet der at de bremsa 1076, ett eller annet også...
d-link Posted January 18, 2006 Posted January 18, 2006 Går unna den der og ja for å si det mildt .. Men fortsatt helt satt ut av den Skyline'n jeg. Minde volum, færre sylindre OG 4x4 og like mye effekt. Im blow'n away! [-] Ford Escort RS Turbo S2 - Prosjektbil - 1.6 CVH EFi, Koni, Cobra, Piper 285T2, Deflex, AP Racing, Megasquirt II v3.0, 2,5" Mongoose, Radtec Intercooler, Escos dyser, Cossiebremser, T3 .48 eksos, 7,4:1 cr, Mintex, Lockheed, Toad CarAlarm, AutoGauge, HKS, Innovate Motorsports, SFS Silicone hoses, OMP, 9mm core plug wire [-] Ford Sierra 2.0iS - Bruksbil - kent cam FR34
