Guest spurs Posted November 1, 2005 Share Posted November 1, 2005 (edited) til salgs, haugesund4 gode sommerdekk på felg, 165/80 r 13, sota baklykter i go stand til sierra combi/5-dørs mk2, pipercross luftfilter har vore på en 89' sierra 2.0 L gasser - solgt2 kanals forsterker - Macrom+ ny kent trimkam til sohc pinto motor, KCFR32K Camshaft kit ohc fast road - Description: KENT CAMS FAST ROAD CAMSHAFT KIT: SOHC PINTO (CARB) Other Info: 2500-7000rpm .442" LIFT, 285/280deg DURATION, TIMING 108deg .010"/.012" CLEARANCE. KIT INCLUDES: CAMSHAFT, FOLLOWERS, VALVE SPRINGS, BALLS STUDS, SPRAY BAR, STEM SEALS & CAM LUBE. https://www.burtonpower.com/Default.aspx prisantydningerforsterker: 500dekk på felg: 500luftfilter: 200trimkam: 2700baklykter: 800 gi bud Edited May 21, 2006 by spurs Link to comment Share on other sites More sharing options...
morty999 Posted November 1, 2005 Share Posted November 1, 2005 få noe specs på kammen a Link to comment Share on other sites More sharing options...
Lompe Posted November 2, 2005 Share Posted November 2, 2005 skal du ha for baklyktene da? Sierra 1986 3 dørs ohc. Sierra 1987 coupe prosjekt..---> [sOLGT] HER Link to comment Share on other sites More sharing options...
Guest spurs Posted November 2, 2005 Share Posted November 2, 2005 (edited) få noe specs på kammen a Kam: FR32K Camshaft kit, kjøpt fra BurtonPowerhttp://www.burtonpower.com/ Pris: betalte £269.20 inkludert frakt når eg kjøpte den.. gi bud skal du ha for baklyktene da?gi bud Edited November 2, 2005 by spurs Link to comment Share on other sites More sharing options...
Guest spurs Posted November 7, 2005 Share Posted November 7, 2005 ingen som vil ha?? Link to comment Share on other sites More sharing options...
Guest spurs Posted April 26, 2006 Share Posted April 26, 2006 Alt er fremdeles til salgs... ingen som vil ha?? Link to comment Share on other sites More sharing options...
alibaba Posted April 26, 2006 Share Posted April 26, 2006 Luftfilteret er av merke Pipercross. x - RS Turbo S2 Link to comment Share on other sites More sharing options...
Guest spurs Posted April 26, 2006 Share Posted April 26, 2006 stemme d Luftfilteret er av merke Pipercross. Link to comment Share on other sites More sharing options...
Kindher Posted April 26, 2006 Share Posted April 26, 2006 funker den kammen på en vanlig IS? eventuelt pris du har tenkt deg? 87 orion 2.0 Zetec: http://www.fmcn.no/forum/index.php?showtopic=7430 Link to comment Share on other sites More sharing options...
Guest spurs Posted April 26, 2006 Share Posted April 26, 2006 skal vel funke på alle sierra sohc med gasser, kan høre med burtonpower funker den kammen på en vanlig IS? eventuelt pris du har tenkt deg? Link to comment Share on other sites More sharing options...
Guest xion Posted May 18, 2006 Share Posted May 18, 2006 (edited) Hei har du solgt baklyktene?? har en sierra 2.0 is 87 combi mod, passer de til den? (Burde vel det) er ikke sikker på om det er mk2. Edited May 18, 2006 by xion Link to comment Share on other sites More sharing options...
Guest oddev Posted May 18, 2006 Share Posted May 18, 2006 Specs på forsterker? Link to comment Share on other sites More sharing options...
donald Posted May 19, 2006 Share Posted May 19, 2006 Hvor i Haugesund holder du til? Luftfilteret er interresant viss det ikke er solgt. 2006 Ford Focus 1.6 TDCi1992 Sierra 2.0 DOHC Sedan SOLGT Link to comment Share on other sites More sharing options...
Guest spurs Posted May 21, 2006 Share Posted May 21, 2006 heibaklytene har eg fremdeles.! Hei har du solgt baklyktene?? har en sierra 2.0 is 87 combi mod, passer de til den? (Burde vel det) er ikke sikker på om det er mk2. Link to comment Share on other sites More sharing options...
Guest spurs Posted May 21, 2006 Share Posted May 21, 2006 har desverre ikke mer specs enn det som allerede står Specs på forsterker? Link to comment Share on other sites More sharing options...
Guest xion Posted May 22, 2006 Share Posted May 22, 2006 heibaklytene har eg fremdeles.! hvor mye skal du har for de da, og kan du sende de til skien? Link to comment Share on other sites More sharing options...
Guest xion Posted May 31, 2006 Share Posted May 31, 2006 hvor mye skal du har for de da, og kan du sende de til skien? 500 ink. porto ?? Link to comment Share on other sites More sharing options...
Ecossie Posted November 11, 2007 Share Posted November 11, 2007 Hei.. Er det komplett Kent kam ?.. Pris ?Inntr å bytte i no ?.. - Is-Turbo - - KNA Gatebil Telemark -- Sviddgummi.no - www.sviddgummi.no Link to comment Share on other sites More sharing options...
Guest Dagfinn Posted November 11, 2007 Share Posted November 11, 2007 sjekk dato:) Link to comment Share on other sites More sharing options...
