cossie2hjulstrekk
    Akershus
Contact Methods
  • MSN
    erik@claptons.net
  • Interesser
    Cosworth
cossie2hjulstrekk's Achievements
Ford
Ford (5/6)
  1. Funnet ut av problemet? har du BB lambda? har du sjekket så det ikke er noe med bensintrykkreg? legg opp evt en måler så du kan se bensintrykk under belastning, lader du 1 kilo så skal bensintrykket øke med 1kilo. sjekk TPS`n som nevt her før; It is used mainly to fine tune the fuel delivery for driveability and fuel economy, a faulty sensor could cause big problems though. The sensor indicates when the throttle is shut so that the ecu can take control of the engine speed using the idle speed control valve and also on deceleration, when the revs are high enough, the fuel can be shut off which helps mpg. It also indicates when a lot of throttle is being used, so the mixture can be made richer for maximum power. There are two types of sensor. The PF01 used on the level 1 and level 6 ecu and the PF09 used on the level 8 ecu. PF01 - this is a variable resistor but with a switch in series with the wiper so that when the throttle is closed the output goes open circuit. The idea behind this is that the closed position is clearly defined. The sensor must be set up so the slightest movement will close the switch and the voltage will change from 5v to 4.4v.(the voltage decreases to 0.35v when the throttle is fully open). The disadvantage is that the most likely fault is an open circuit due to wear or a wiring problem, which cannot be identified by the ecu and so will not flag up a fault. A faulty output could cut the fuel during normal driving causing misfires or an engine which won't rev. The setting up of the switch position is critical as the throttle does not have to open very far for the revs to rise and the ecu must realize that it is the throttle controlling the revs and not the idle speed control valve, the result may be surges or stalling. Sjekk at du har god jording til motoren og til hjernen.
  2. Ønsker kjøpe: -Taktrekk -lås sett (evt lås sett til is) -Luftfilterboks //Erik Bakke Akershus 90759726
  3. Ønsker kjøpe komplett lås-sett til vingebil. nødvendigvis ikke tenningslås, men til dørene og bakluke. //Erik Bakke Akershus 90759726
  4. Har fått kjøpt meg sprut, ellers takk.. Tråden kan stenges.
  5. Vet du hva mm på "gaper" på kalipperfeste er som du trenger? jeg har en del sånt liggende men husker ikke hva som er hva. //Erik
  6. Ønsker kjøpe datasprut til en grei pris. må være av nyere type, ikke MS. emerald k6, EMS stinger4, vipec, link g4 el. //Erik Bakke Akershus 90759726
  7. Har du målt TPS`n så den er linjær? ofte er de TPS`ene fine på 0% og 100% men har dropp på veien fra 0-5v
  8. det ble montert l8 ecu med PF09 TPS sensor og pukkelrygg kopierte l6 chip`n over til L8.
  9. Ønsker kjøpe: -Frontfanger -Grill -Venstre framskjerm //Erik Bakke 90759726
  10. Ønsker kjøpe: Strøkne baklamper med lampeholdere Strøkent taktrekk Lås til bakluke med nøkkel ( samme som vanlig sierra kanskje?) //Erik 90759726
  11. Oppdatert med bilder av det som er igjen: HER
  12. T35 med 360lager, .63 eksoshus. null slark 4000,- Akershus tlf: 90759726
  13. Hei! det har jeg ta kontakt på 90759726 Jeppers, det stemmer Jepp jeg kan sende. ring meg så blir vi enig. 90759726 beklager det er solgt
  14. da kliner jeg til med bud på 800
