vingesvin
Everything posted by vingesvin
  1. http://www.finn.no/finn/car/used/object?finnkode=27108963 HAHA
  2. Får håpe bilen blir klar til vårmønstringo.
  3. 3dørs is i bra teknisk stand med skilter øk! Betaler godt. 94895486 - André
  4. http://www.rscosworthbreakers.co.uk/newparts.html
  5. Peneste vingevogna eg veit om
  6. Samma kor fine bilen er, hjelper veldi lite vist ikke du får den godkjennt ombygd.
  7. http://www.rscosworthbreakers.co.uk/
  8. Slenge eit bud på 6 eg då. Rekna med da 4wd?
  9. Kristian (Escort_rst_wrc) hadde ET35 på bruks cosworthen, med 215/35 og dette gjekk heilt fint.
  10. Fortell.
  11. Dear customer We are proud to an ounce in January we will have our cosworth 200 YB alloy blocks ready for marketing , we have been testing them for some time now in drag racing and rally engine with some incredible results , Manufactured from Grainger & Worrall - Super-Cube Machined Castings. Foley Patterns of Kidderminster designed and manufactured the first class casting equipment that is used to produce the ATMsport YB block castings. They aslo do work for the F1 teams, YB Aluminium Cylinder Blocks are tailor finished to meet the individual needs of their customers´ YB Blocks - STD Block Kit Includes: * Any Bore Size between: 90.8mm - 96.0mm * Any Block Deck Height between: 207.5mm(std) - 221.5mm (+14mm) * Steel Main Caps * ARP Main Caps Studs * Special Ductile High Strength Cylinder Liners (Honed to size) * Dowels / Core Plugs / Oil & Water Plugs * Std Head Bolt Machining * 2wd Water Pump Machining * Long-stroke machining & special breather baffle * * Price = £3,600.00 YB Block Options * Piston oil squirt jets x4 (supplied and fitted) * Long Stud kit x10 - Special Deep engagement - Hi-Boost * Tall Block Idler & Cam Belt Kit - 2 Types * Multi-Shim Big Bore Head Gaskets 95-96mm * Std ARP Head Stud Kit For any more infermation or photo's contact sales@atmsport.com Kanskje dette er interessant for noen? Eller om noen vet noe om desse? Dette er IKKE samme blokkene som er solgt av cosworth.
  12. 25k for ein 205 motor er litt mye. Men med tanke på at turbo og allt "skal være 100%" så kanskje du får 18-20k. Men du seller som sagt ein motor du ikke er sikker på er overhalt. Du har vell bare fått beskjed om det. Hadde det vore ein 200 motor skulle 25k ikke vore noe upris.
  13. 205 2wd motor ØK! Helst ikke over 15.000. Kan godt vær sleten, treng heller ikke følle med mainfolder. Mvh André 94895486
  14. Kva kammer er det du kjører da?
  15. Kjekkt for deg da. Trudde du fekk da med deg i sist topic eg.
  16. 7000,- Synest ikkje du da e litt drøyt og betala ekstra for at du ikkje gidder og bestille sjøl?
  17. Dette er TTD motorsport i spania. Det er inkludert frakt og moms ja. Reyland har ikkje rettighetene lengre. Her har du mailen adiaz@ttdmotorsport.com
  18. Dette er Compomotive TH felger fra TTD motorsport. Desse kommer på rundt 12.000,- hjem på døra.
  19. Eller en eldre sierra? ;D
  20. Du vet vell at psi og bar ikke er det samme?
  21. Ser ut som det er likt. Bare svart.
  22. Som topic, kan godt vær uten eingongsavgiften. Helst i orginal (204-350. Ring 94895486
  23. bump
  24. Ring meg på 94895486
  25. Den første er jo langt vekke, den nederste er solgt Men takk for du gidde hjelpa leita ;D
