derekd
Everything posted by derekd
  1. pris!!!
  2. ja det loddes til kontakten til hjernen enkelt
  3. har lagt den inne annonse nå
  4. har et set nå solgt en til veldig bra pris:)
  5. kan hentes i ringsaker eller sendes tlf99292976 eller pm litt info om den The ECU DATA MONITOR is a device for monitoring the ECU sensors and engine performance. This was designed to give the driver information about the operation of the engine as seen by the actual engine managment sensors. This unit is wired in parallel with the ECU and so does not care which type of ECU or chip is fitted to the car. (Does not support EEC4 cars yet). The display shows real time data of the sensors in numeric and graphical format and also records peak operating data. Data is displayed on a backlit Black on yellow LCD and operation is with two push buttons. The unit continuously monitors sensors and checks for faults as well as user adjustable alarms and when a fault or alarm occurs, an output is energised to drive a lamp or buzzer to warn the driver of possible problems. The user can set alarms for HIGH BOOST, HIGH CHARGE TEMPERATURE, HIGH COOLANT TEMPERATURE, HIGH BATTERY VOLTAGE and LOW BATTERY VOLTAGE. In addition to the monitoring, control of a water injection pump comes as standard. This is controlled by wiring an external relay to drive a pump and the user can adjust all settings required to drive this such as boost pressure and charge temperature. Supplied in a black or gray plastic box or an in dash bezel to replace factory fitted clock
  6. oki fikk min på escort justert på verksted på eu kontroll og gått gjenom eu sånn så regner med det er bra nok!!!
  7. morettes passer begge det!! er vel justering på dom har bud på 4000kr på et sett nå
  8. solgt
  9. bump
  10. 4x4 cossie skiver foran x2 solgt
  11. dom er ny i pakke sa er svart plast
  12. bump
  13. solgt
  14. bailey turbo damper breather tanken swirl pots motorsportr plugger til coil packs kan sendes eller hentes i ringsaker bud ønskes pm eller tlf 99292976
  15. satt på ecu jeg kjøpt men skal prove en fin ut for deg
  16. bump
  17. bilder lagt til!! dump valve, breather tank solgt
  18. har bailey swirl pot til salgs øgså
  19. derekd
    4x4 cosworth
    mt75 cosworth gir kasser circa pris!!
  20. bump
