RSCLASSICS
Everything posted by RSCLASSICS
  1. GARY AT RS CLASSICS OK RE-ADVERTISED DUE TO TIMEWASTER!!!BRAND NEW IN BOXES £675 ovnoMK2 ESCORT 3 OF 8X15 WHITE 5 SPOKE REVOLUTION WHEELS2 OF 9X15 WHITE 5 SPOKE REVOLUTION WHEELS
  2. MORE PARTS IN
  3. SIERRA COSWORTH T34.63 TURBO £450 SIERRA COSWORTH T34.48 TURBO £400 BOTH TURBOS HAVE A VERY LITTLE PLAY BUT NOTHING REALLY
  4. SWIRL POTS AND HEADER TANKS 3DR SPEC R WITH GLASS WINDOW £135 SWIRL POTS FROM £65 STRUT BRACE £55 FUEL PUMP CRADDLE COMPLETE WITH 044 PUMP £125 COSWORTH SILL COVERS FROM £25
  5. MORE PARTS IN TODAY NEW COMPRESSION STRUTS AND ADJUSTABLE TCA £275 PLUS POST NEW ENGINE MOUNTS £80 PLUS POST LOMGER DRIVE SHAFTS £125
  6. ALL PARTS AVAILABLE MORE PARTS IN TODAY
  7. 4X4 COSWORTH CYLINDER HEAD ALL IN GOOD CONDITION MEASURES 138.8 AND COMES COMPLETE WITH VALVES , CAMS ETCREADY TO FIT£850 PLUS POST
  8. RED 2WD AND 4X4 CAM COVERS FROM £135 T5 FIFTH GEARS £120 EACHLOCKWOOD WHITE DIALED CLOCKS £55WHITE DIALED CLOCKS NOT LOCKWOOD £45BLACK CAM COVER £1354X4 KONIS £175SET OF 4 LATTICE WHEELS £225GENUINE 3 BAR MAP SENSOR £150ORIGINAL GREEN CAM CVER £145SWIRL POT £65RED SAMCO BOOST HOSES £70ESCORT COSWORTH CAM BELT COVER £85SET OF 403 GREYS £150WINDOW SWITCH £17.50GOOD CARRELLI HEADLIGHTS £60 PAIRSTAGE 3 ECU LEVEL 6 £185CLEAR INDICATORS £20 PAIRCLUTCH FORK COVER £202WD CAM BELT COVER £554X4 WING BADGES VERY GOOD £35FOG LIGHT SURROUNDS £35 REAR DOOR COVERS £35 PAIRLEVEL 8 ECU STAGE 1 £275GOOD MOTORSPORT BLUE HT LEADS £552WD PLASTIC HEADER TANK £85FACE LIFT 4X4 DASH (SMALL CRACK ON TOP) £35VERY GOOD 3DR HEADLIGHTS £100T34 SILICON BOOST HOSES £35 EACHPF09 THROTTLE POSITION SENSORS £75CONE AIR FILTERS £55SMALL SWIRL POT £60
  9. WILL POST INTERNATIONALLY AND TAKE PAYPAL AS PAYMENT ALSO Stage 3 chip Running a t3 turboDark green injectors3 bar map sensor044 fuel pump with new wiring kit fittedNew fuel filter and new fuel pump holderAll the sensors changedLarge air filterNew radiator with uprated fan cut in switchBig intercooler AL PARTS AVAILABLE!!!!!!!!!!!!! THIS CAR WILL BE STRIPPED AND EVERYTHING WILL BE AVAILABLE APART FROM THE WHEELS AS I MAY KEEP THEM. ENGINE IS SWEET AND BOX IS GOODSHELL NEEDS ATTENTION BUT STILL FOR SALEHAS GOOD LEATHER SOLDRS500 COOLERLARGE CONE FILTER SOLD!!!!!!!!!!!AMBER REARS AND FRONTS ETC[/b][/size] DUE IN TODAY FOR BREAKINGSHELL SOLD!!!!!!DOOR CARDS ARE THE BEST I HAVE SEEN !!!!!!!!!!!!!!!!!! SOLD!!!!!!!LATE SPEC FACELIFT 4X4 SAPPHIRE COSWORTH.GREEN TOP ENGINE WITH AIRCONRUNNING GREENS AND 3BAR ETCSTAINLESS SYSTEM.LEATHER INTERIORETC ETC ALL PARTS AVAILABLE FROM MONDAY AS CAR IN TODAYleather front seat sold!!!!!!!!!!!!!!
  10. cosworth breaking 2wd and 4x4 parts OSWORTH PARTS UPDATED WILL POST INTERNATIONALLY AND TAKE PAYPAL !!!!!!!!!!! PARTS ALWAYS CHANGING STOCK ALWAYS CHANGING AND CURRENTLY BREAKING ONE 2WD AND ONE 4X4 COSWORTH BLING AND SHINNY BITS (JUST ASK MORE IN STOCK) BLACK ALLOY CAMBELT COVER £65 SLAM PANEL BLANKS £12.50 STAINLESS HEAT SHIELD £117.50 SOLD!!!!!! FUSE BOX COVER £20 OIL SCREW CAP £20 AMAL VALVE COVER £17.50 SOLD!!!! ACTUATOR COVER £17.50 ALLOY PAS TANK £55 AIR BOX CLIPS £12.50 WHEEL CAPS REVOLUTION £10 4X4 STEERING WHEEL £75 COLLINS BOOST GAUGE £35 GROUP A FILTER £55 stainless bottom rad pipe 2wd £20 BAILEY 2WD HEADER TANK £85 SWEDISH STYLE PLENIUM LIKE NEW COMPLETE WITH BRACKET AND THROTTLE BODY (BLUE) £400 SWEDISH PLENIUM THROTTLE CABLE BRACKET £25 STANDARD 2WD REGULATOR NEVER BEEN MESSED WITH £45 SOLD!!!!!!!! STAINLESS CONE FILTER COVER £25 RS TURBO OIL CAP £15 ENGINE PARTS (JUST ASK MORE IN STOCK) 4X4 ENGINES FROM £2500 2WD COMPLETE ENGINE £2300 GREEN INJECTORS 803 £125 PLUS POST YELLOW INJECTORS £45 POSTED LIGHT BLUE INJECTORS MOTORSPORT 400 £150 POSTED GREY INJECTORS £125 4X4 CRANK STANDARD GRIND £450 ono SOLD!!!!! 4X4 THROTTLE POSITION SENSOR PFO9 RED £75 ono 4X4 THROTTLE POSITION SENSOR PFO9 BLACK £75 ono SOLD!!!!!!!!! 4X4 SUMPS £85 2WD SUMPS £110 2WD/4X4 BOTTOM PULLEYS £75 2WD OIL PICK UP PIPE £35 4X4 OIL PICK UP PIPES 2WD CAM BELT COVER £35 HT LEADS £45 SILICON CAM COVERS FROM £125 PLUS POST £12.50 RED SILICON BOOST HOSES £55 ORIGINAL 2WD DIPSTICK AND SHROUD £30 BOOST HOSES £55 RAD FANS £25 2WD INTERCOOLER £35 4X4 HEAT SHIELD FOR VENTED BONNETS £40 GROUP A COIL £15 boost pipe RS500 £70 RS 500 INTERCOOLER £125 motorsport ht leads £55 plus post 4x4 turbo very good £225 WATER INJECTION TANK £45 2WD AND 4X4 ABS PUMPS £45 SAMCO BOOST HOSES BLUE £55 3 bar map sensor repaired and works perfectly £45 GROUP A COIL £15 PLUS POST ESCORT COSWORTH STANDARD MAP SENSOR £25 PLUS POST 4X4 INTERCOOLER £55 PLUS POST 4X4 MANIFOLD £100 TINY CRACK 2WD SANDWICH PLATES £25 4X4 SANDWICH PLATES £20 TRANSMISSION (JUST ASK MORE IN STOCK) 2wd gearbox complete with bell housing and fork (no mount) £550 4X4 GEARBOX £275 2WD GEAR LEVER £25 2WD FRONT HUBS £85 ABS SENSORS £20 EACH ABS PUMPS £70 STEERING RACKS £75 2WD AND 4X4 ANTI ROLL BARS £35 2WD/4X4 FRONT CALIPERS £85 2WD/4X4 REAR CALIPERS £85 2WD AND 4X4 KONIS £175 V GOOD 2WD 7.5 INCH REAR DIFF £250 QUAIFFE DIFF 2WD £1000 ono 2WD REAR CROOVED DISCS £40 PAIR 2WD DRIILLED AND GROOVED FRONT DISCS £30 PAIR REAR DRIVESHAFTS £85 PAIR 2WD AND 4X4 REAR BEAMS £35 REAR ARMS BARE £25 EACH PROP SHAFTS 2WD £45 WHEELS (JUST ASK MORE IN STOCK) ESCORT COSWORTH WHEELS AND GOODYEAR TYRES £600 5 SHARKTOOTH WHEELS AND CAPS GOOD MATCHING TYRES £400 3DR COSWORTH WHEELS X4 £175 3dr wheels available we have over 70 of them that need some re-furd £35 each 3DR WHEEL LOCKS AND KEYS £175 3DR WHEEL CAPS £25 EACH SAPPHIRE WHEELS SET OF 4 £175 WITH TYRES BLACK SAPPHIRE SET OF 4 £145 NO TYRES SOLD!!!!!!!!!!!!!!! 17 INCH KHANS £225 17 INCH OLD SCHOOL CHROME WHEELS £150 5 SPOKE MO COMPOMOTIVES £700 SET OF 4 WITH TYRES SOLD!!!!! TSW 18 INCH WHEELS £350 SET OF 4 SOLD!!!!!! BODY PANELS (JUST ASK MORE IN STOCK) SAPPHIRE COSWORTH REAR SPLASH GUARDS £30 EACH OR £50 PAIR sapphire grilles £45 plus post sapphire grilles less centre £20 SAPPHIRE COSWORTH HEATED FRONT SCREEN WITH TOP TINT £150 GENUINE SAFF FRONT AMBER £65 PAIR 4X4 BONNETS £110 SAPPHIRE COSWORTH BLUE FRONT BUMPER £225 ESCORT COSWORTH MINT HEADLIGHTS £80 ono JACKING COVERS £17.50 EACH PLUS POST SAPPHIRE clear front indicators £30 3DR WHALE TAILS £225 3dr cosworth skirts NO ARCHES genuine £80 pair PASSENGER SIDE REAR QUARTER 3DR TRIM £65 PLUS POST 3dr Jacking covers £15 each SAPPHIRE REAR SPOILERS £45 DOORS £45 EACH BACK BUMPERS FROM £80 SIDE SHIRTS WITHOUT JACKING COVERS £65 WITH COVERS £120 INTERIOR (JUST ASK MORE IN STOCK) WHITE DIALED 3DR CLOCKS £85 PLUS POST FORD STEREO £35 4X4 SAPPHIRE CLOCKS £45 LEATHER INTERIORS FROM £400 CLOTH INTERIORS FROM £250 3DR INTERIOR FRONT/REAR SEATS £450 CARPETS FROM £45 2WD STEERING WHEELS £100 4X4 STEERING WHEELS £65 SAFF CLOCKS SURROUND £20 L6 ECUs FROM £145 STAGE 3 L6 ECU £185 L8 ECU FROM £250 2WD REAR PARCEL SHELF SPEAKERS £30 PAIR FOG LIGHT SURROUNDS £25 PAIR DASHES FROM £45 2WD, 4X4 AND FACE LIFT MODELS 2wd horn push £20 ESCORT COSWORTH REAR CARPETS £40 PAIR 4X4 Saff ecu holder £20 LOCKWOOD WHITE FACED CLOCKS £60 UPRATED FUEL REG £45 REAR ARCH LINERS £60 PAIR GREEN INJECTORS £125 GREY INJECTORS £150 STAINLESS CONE FILTER COVER £20 ACCELERATOR BRACKET £25 OIL CAP RS TURBO £10 WHITE 7.5 X 17 COMPS WITH RALLY TYRES £750 BLACK 7.5 X 17 COMPS WITH TYRES £750 RED CAM COVER £135 3DR REAR PARCEL SHELF HOLDERS £50 PAIR 3DR REAR STRUT COVERS £45 PAIR PLASTICS 3DR RS ECU COVER £75 3DR DASH BIT CRACKED £85 3DR WINDOW COVERS £30 PAIR MINT 3DR COWLING £45 4X4 BADGES £30 STAINLESS ACTUATOR COVER £15 STAINLESS MAP SENSOR BRACKET £15 BLUE SWEDISH PLENIUM COMPLETE WITH THROTTLE BODY £425 LESS THROTTLE BODY £300 4X4 SHARKTOOTH WHEELS £350 STAINLESS WINDOW SWITCH £10 CONE FILTERS T34 PIPES 3 BAR MAP SENSORS ESCORT COSWORTH SUMP GUARD BRACKETS 2WD SUMP £125 ESCORT LOWER SPOILER T5 GEARBOX TAIL HOUSING BAILEY PAS BOTTLE £65 WILL POST INTERNATIONALLY AND TAKE PAYPAL AS PAYMENT ALSO Stage 3 chip Running a t3 turboDark green injectors3 bar map sensor044 fuel pump with new wiring kit fittedNew fuel filter and new fuel pump holderAll the sensors changedLarge air filterNew radiator with uprated fan cut in switchBig intercooler AL PARTS AVAILABLE!!!!!!!!!!!!! THIS CAR WILL BE STRIPPED AND EVERYTHING WILL BE AVAILABLE APART FROM THE WHEELS AS I MAY KEEP THEM. ENGINE IS SWEET AND BOX IS GOODSHELL NEEDS ATTENTION BUT STILL FOR SALEHAS GOOD LEATHER SOLDRS500 COOLERLARGE CONE FILTER SOLD!!!!!!!!!!!AMBER REARS AND FRONTS ETC[/b][/size]
